Smaller ES-335 (ES-337?) build
12345679»
  • davrosdavros Frets: 1352
    Pickguard is now fitted, but I need to make a little block to fit on the back of the pickguard. The bracket I have came with a metal block that screws into the pickguard.
    Drop fill is in progress, waiting for the black drop to dry a bit before building up with clear.
    And, the sharp posts have been dealt with using a dremel cut off wheel, grindy bit and polishing bit with some rouge. Much comfier!
  • skippy76skippy76 Frets: 616
    Nicely done! Looks spot on
  • PeteCPeteC Frets: 409
    Absolutely superb build  - great to watch this one take shape.   That’s a fantastic looking semi, you should be really proud of that.   Very inspiring work @Davros
