Also put bigger seats in so thinks her bum has got smaller.
Double win. ;-)
But I'm not wrong.
Not saying 'don't do it', just is this the best way forward?
Also, as I said...this will probably be a test-run for doing my MG, so it won't be a wasted effort even if she doesn't like it
Sadly, around here, the process seems to have a side effect of making the driver need to maintain just inches of distance behind you and overtake in villages while listening to dnb, but hopefully you'll have immunity to this side effect!
Nice to hear you still have the MG. My mate had one, nice car once the head gasket was sorted (preemptively...) and he bolted down the bonnet after a minor collision.
Feedback
Trouble is, I can't make one in advance without the wife noticing, and I'll only be able to send her away for a couple of days at most.
I've sprayed guitars.
I have access to a spray booth just up the road.
When my car needed a spot repair I took it to a man and he made the problem go away for a nominal amount, certainly less than it would take to fix if I fucked it up.
It's about £350 for the kit (including the turbine gun), and I'm looking around at pop-up marquee tents for the driveway...looks like that'll be about £150.
