Removing Cigarette Odor From A Guitar
13»
  • droflufdrofluf Frets: 3737
    Offset said:
    mark123 said:
    stonevibe said:
    Rub cat piss on it  ;)
    how do you get rid of cat piss smell?
    Smear it with fox shit.
    And if that smell is overpowering it can easily be removed by blowing cigarette smoke over it.
  • SassafrasSassafras Frets: 30301
    Some manly aftershaves smell of tobacco and they guarantee sexual virility and make you irresistible to the opposite sex,
    I'd be trying to increase the smell of tobacco on everything I own.
  • mark123mark123 Frets: 1325
    Its the painting the Forth bridge senario...
  • KittyfriskKittyfrisk Frets: 18919
    rhinofeet said:
    I had a stinking Peavey backstage and bombed it with all kinds of air fresheners and soap and baking soda etc. Didn't work. Eventually I covered it in hand sanitizer gel and left it in the sun, smell was gone in an hour. Not sure how this will affect you let guitars finish though
    @mark123 lives in Sunderland man. Leave a guitar in the sun (or even in a van) & it'll be gone before the smell...
  • OffsetOffset Frets: 11934
    You could try spraying this in your guitar case - not sure if it would be safe to apply directly to the guitar but you could test a small tucked-away spot.
  • jonnyburgojonnyburgo Frets: 12410
    If you can figure out how to burn Joss sticks in the case without burning it do that, then they might not burn due to lack of oxygen.I don't know what you should do.
    "OUR TOSSPOT"
  • rlwrlw Frets: 4728
    Jet wash
    No case just the guitar , it was going to go outside in the back garden on a stand but belting down now , had hailstones ! .
  • hollywoodroxhollywoodrox Frets: 4200
    I had a Marshall valvestate  I bought on eBay that reeked of mood . I cleaned it all over with wipes
    sprayed the speakers inside with dry hair shampoo spray . I then put incense cones in every night ,two or 3 and burned them . It was also left in the sun . After a week of incense burning  the mouldy smell was gone and I could sleep in the same room as the amp
  • steven70steven70 Frets: 1278
    edited July 2023
    I don't smoke, but I like the smell of second hand cigarettes. Something comforting about it...
  • cbakaycbakay Frets: 67
    There will still be radiation in Chernobyl by the time the cig smell is gone. You can try to mask it though - music nomad's polish has a nice smell and may rid the outer layer of gunk that's holding some of the smell. Also will have to change the case...
