SPEAKER IMPEDENCE CALCULATOR
I can't afford them so I use masking tape.
Bought some LED dimming film from Amazon, comes in some pre-cut shapes. Dims them well, but occasionally falls off.
https://www.thefretboard.co.uk/discussion/206073/paying-it-forward
I guess it depends on how dark your stages are (or bedroom is) but unless you are staring straight at your pedalboard all night (I'm looking at you Shoegazers) its a bit of a first world problem, nes pa?
Well perhaps but if you read as many equipment reviews as I do you will know that once in a while this problem is cited and it can be a nuisance when the intensity of the LED 'blinds out' the settings on the equip
