If you had to choose a very basic pedal set up,
  • digitalscreamdigitalscream Frets: 26670
    Chorus -> Boost -> Distortion -> Delay
    Which, coincidentally, is exactly what I have on my board.
    <space for hire>
  • vizviz Frets: 10709
    OD
    OD > Delay
    Wah > OD > Delay
    Wah > OD > Delay > Boost
    Wah > OD > Delay > Chorus > Boost
  • ICBMICBM Frets: 72508
    LionAquaLooper said:
    So the Zoom G3X then
    I've still got one and still one of my favourites
    I did try one - actually the more basic G3, without the wah - it was quite good. I had the bass version for a while too. Still prefer the Boss, but I could live with the Zoom.
  • SupportactSupportact Frets: 979
    Tuner
    OD
    Delay
    That would probably get me through. Would like tremolo as well but not essential.
  • SporkySporky Frets: 28533
    A big multiFX. Just one unit, so "basic".
  • NeilybobNeilybob Frets: 794
    A good fuzz (with the guitar volume knob you can go from clean to OD to distortion to fuzz)
      Boost
      Reverb
  • ... I would just give up guitar  :'(
  • snowblindsnowblind Frets: 296
    How about just an amp with built-in FX?
    Nah. Only kidding. Unless maybe that amp is a JC120?
    Old, overweight and badly maintained. Unlike my amps which are just old and overweight.
  • Assuming I was using an amp with reverb and trem I’d have fuzz > tuner > phaser > tape echo.
    If I was being super basic I’d be able to cope with just fuzz.
  • NelsonPNelsonP Frets: 3402
    edited February 18
    Fractal FM3.
    Oh wait, basic you say, and no brand names. Hmm - fail.
  • GreatapeGreatape Frets: 3596
    Tuner, drive, delay. (Assuming amp doesn't have a drive channel).
    If I could have four, add a volume pedal.
    If I could have five, add modulation.
  • TeyeplayerTeyeplayer Frets: 3230
    Tuner, drive, phaser, tremolo, reverb
    In fact, I really should simplify my board to just this.
  • Matt_McGMatt_McG Frets: 327
    Drive - Tremolo - Phaser - Delay - Reverb
    Assuming the amp doesn’t have trem or reverb. I could replace trem and phaser with a good univibe or harmonic tremolo. I could do without delay, too, so a minimal board:
    drive - harmonic tremolo - reverb
  • robertyroberty Frets: 10893
    Ring modulator straight into the PA
    5reaction image LOL 0reaction image Wow! 2reaction image Wisdom
  • guitars4youguitars4you Frets: 14312
    But that amp only has one sound - However what a one sound it is and very rarely do you come across a pedal that captures that sound, so well
  • ColsCols Frets: 7081
    robgilmo said:
    Without naming brand names, just type, what would it be?
    Is this going into a magnificent multichannel amp going all the way from shimmering cleans to Meytallll, with a boost switch and switchable reverb?
  • Rowby1Rowby1 Frets: 1280
    As an absolute minimum it’d be:
    Tuner
    Overdrive
    Reverb
  • AlexlotlAlexlotl Frets: 176
    Assuming I can have reverb from my amp and a clip-on tuner, then it would be OD, Fuzzstortion (Muffish or Ratish) and Chorus.
  • DrCorneliusDrCornelius Frets: 7219
    A tuner and a Deco
  • distresseddistressed Frets: 537
    edited February 18
    How basic should it be?
    1. Fuzz
    2. Fuzz > Delay
    3. Fuzz > OD > Delay
    4. Fuzz > OD > Tremolo > Delay
    5. Fuzz > Fuzz > OD > Tremolo > Delay
    6. Fuzz > Fuzz > OD > Tremolo > Delay > Reverb
    *SHO at the end of chain in every instance
