If you had to choose a very basic pedal set up,
  • I stripped my gig board back to the minimum I could get away with and ended up with:
    Tuner
    dirt + a boost (either a twin pedal or as two separate pedals)
    delay
    Thats gets me through a gig with the basics covered.
     I generally prefer to a have a wider palette of tones available but I think it’s good practice to strip back once in while to see if you can manage your set without all the bells and whistles.
  • Two different types of drive (maybe a distortion and an OD). Some delay - DD3, to give a bit of something).
    I’ve found SD1, into Blues Driver, into DD3 is very very flexible.
    One can be a boost.
  • BlueingreenBlueingreen Frets: 2612
    In olden times I played for a long time with a single Boss Chorus pedal into a master volume amp with reverb.
    More recently I've played a number of gigs with just a Flyrig 5.  I'm currently using an HXFX for a bit more flexibility but it would be no real hardship to go back the FR5.
  • jellybellyjellybelly Frets: 767
    Basic = 3 pedals I'd say
    - Drive (whatever works for your style, but probably a Rat for widest range)
    - Delay
    - Zoom Multistomp
    The drive and delay cover 80%+ of all actual recorded guitar tones and effects, the zoom clears up everything else. It's got great boosts, some good drives and compressors, some really good modulation sounds, decent delays and a smattering of weird stuff like lofi takes on Strymon and Eventide effects, or reverse reverb. Plus the tuner is great.
    A true bypass loop for it is handy as it lets you cycle through presets easily with the pedals footswitch.
    All that said, a HX Effects or a Boss multi would also take you far. I love my HX...
  • robgilmorobgilmo Frets: 3634
    I see delay gets a popular mention, gassing for delay now.
    My basic set up is Overdrive - Distortion - Chorus. amp has tremolo and reverb. I found overdrive into distortion to make some nice noises.
  • fretfinderfretfinder Frets: 5078
    edited February 19
    robgilmo said:
    Without naming brand names, just type, what would it be?
    Someone's probably said this already but I couldn’t be bothered to read all the comments… It’s impossible to answer without knowing what type of music will be played through your very basic pedal setup.
  • fretmeisterfretmeister Frets: 24683
    Guitar: Tuner, Phaser, Drive, Delay
    Bass: Tuner, drive, compressor, HPF
  • I'm very simple when I play live, all I need is a tuner and noisegate mainly. And a form of boost.
  • CaseOfAceCaseOfAce Frets: 1371
    My pedal philosophy for gigging these days roughly aligns with that of the late Rick Parfitt of Status Quo:
    "I have three pedals; one makes everything louder, one makes everything twinkly, and one turns everything off. It’s not rocket science."
  • ElectricXIIElectricXII Frets: 1160
    For me - tuner, OD, boost, delay. If I didn't have to cover faux organ sounds in our band, for which I use a compressor, EHX C9 and a Mini Vent II, I'd happily just gig with the four pedals I mentioned first.
    I could probably even get away without the boost, as I always play with the guitar volumes on 7 or 8 for rhythm, leaving a bit in the tank for lead stuff.
    I'm surprised how many people list Chorus as a must have, by the way.
  • ICBMICBM Frets: 72728
    The 80s are back in fashion...
    But if you only have it set on one its like, one tenth of the 80's, so that puts it firmly in the Edwardian period,
  • TTBZTTBZ Frets: 2917
    edited February 19
    Assuming the amp has a decent drive channel then tuner in front, lead boost and a tape-sounding delay in the FX loop. If not then MIAB, lead boost, delay and a clip on tuner I suppose.
    My old rock cover band setup was just wah and tuner in front of the amp with an EQ in the loop for solos. Did the job more than adequately! I do like a delay to fill out leads now though.
  • For most of what I do:
    OD > tremolo > reverb
    for my main band:
    wah > OD > tremolo > delay > reverb
    Am I the only one who absolutely needs tremolo to be happy?
  • DominicDominic Frets: 16186
    Klon and a Strymon Deco
    Sad isn't it? I bought a Mooer Ensemble KIng on here a few weeks ago for our covers band, but I'm not even going to put it on my board.
  • FezFez Frets: 536
    Tuner, Drive, Boost if playing a Strat SSS a compressor is useful.
    Don't touch that dial.
    I like tremelo, but for a typical gig I use it on 2 songs out of 45.
    It's a really good way of identifying the people you don't want in your band.
  • DannyPDannyP Frets: 1682
    A tuner and a Deco
    Came to say this.
