Let's make a Trainwreck amp cabinet in London Plane (not walnut as originally thought)
  • guitargeek62guitargeek62 Frets: 4358
    duotone said:
    Love the look of those Trainwreck amps, they are beautiful.
    Enjoyed watching Pete Thorn play through a Trainwreck Liverpool model (in July 2021) this evening
    Looking forward to seeing how this one turns out.
    Most of those tones are exactly the type of things I want from an amp.
    I have zero need for the volume levels that a Trainwreck requires to get the best out of though, but I'd love to find/build a super-low wattage version at ~2w for home use. I imagine that'd change things quite a bit though as I've read a lot about the interaction between pre- & power-amps on these.
    edited February 6
    Hold up - there's a Z-Wreck Jr?!    15w is still f'in loud, but...
    http://drzamps.com/product/z-wreck-jr/
  • KurtisKurtis Frets: 1114
    Looking great!
    From previous experience of building a head cab, it looks like it will be a fair weight?
    Yo momma's on the crack rock!
  • NeilybobNeilybob Frets: 944
    Thanks guys. It's getting there slowly but surely. Hoping to have it finished before the spring.
    @Kurtis you have definitely built a head cab before! Planning to let the neighbours hear it lots lol
    @duotone and @guitargeek62 I do have a attenuator but I do love to play loud also!
    Have you seen this demo of the Ceriatone Expression Trainwreck clone?
    And this one is a great watch also.
    flanging_fed “
    edited February 8
    I think if I ever did it again I'd probably use thin plywood or something thinner and lighter than the stuff I did use. Maybe a nice piece for the front panel.
    It was a mare to cut and shape too!
    Maybe not make much difference right enough with the transformers.
    Mine's just for home use anyway and it looks nice.
    edited February 12
    After much time away from this project we've returned to get it done
    Edges rolled with the router tonight (photos 1, 3 &4). Man this is coming along nicely now!
    We created a paste out of sawdust and PVA glue to use a filler around a couple of the corners that needed a little filler. We've left the filler to dry and then it's time to sand the b'jesus out of it.
    We also had a go at setting up the jig to cut veneer pieces using off cuts of wood (photo 2)
    flanging_fed “
  • RabsRabs Frets: 2648
    Neilybob said:
    Great work..  But also, with this shot I can confirm that, that is 100% London Plane  :D
    Rabs said:
    Thanks Rabs.
    flanging_fed “
  • revsorgrevsorg Frets: 894
    I recently chopped a London plane woodturning blank into cubes, planning to carve numbers and card suits into them to use when playing bridge.   When we're doing woodturning we use a Chestnut three-stage buffing system, which results in a lovely finish to our bowls - among its attributes it eradicates the concentric lines that are otherwise hard to eradicate.  So, I used the buffing system to polish the London plane cubes and was awestruck by the finish, particularly on the surface that has flecks - to me it looks like the feathers on a little bird - a thrush or something.  It's not like any other wood I have encountered, it has one face that has a kind of iridescent depth, with those flecks, while the other faces just look like wood.  I tried to video them to show what it's like, but I haven't really done it justice.  Anyway, I think if you can buff that cabinet it will be worth the effort.
    edited February 12 tFB Trader
    Yes its incredible stuff.. I have been working with it for several years at a timber company. I didnt even know what it was before I started but it is unlike any other wood in its character. You get the lace when it is quarter sawn.. But even without lace it can be anything from pale cream to dark pink, spalted, burry and more (sometimes all in the same piece). Just incredible stuff. I have tried showing it to people on here but other than a couple of people no one was really interested.
    I actually have a project on the go with some spalted plane.. Just look at this
    https://i.imgur.com/c58LVlB.jpg
    https://i.imgur.com/vDGCO3P.jpg
    https://i.imgur.com/Hg70RYN.jpg
    And a short while a go we made some London Plane tiles at work for an order. Something like 2000 of them.. My job  was to oil them all. Talk about variety.
    https://i.imgur.com/YhIWrws.jpg
    https://i.imgur.com/T7JMJlQ.jpg
    Tbh I had never heard of London Plane until I bought this piece thinking it was walnut. Very pleased with it.
    flanging_fed “
  • SporkySporky Frets: 30055
    That spalted bit is quite something.
    Eye catching isn't it!
    flanging_fed “
    I wonder about finish for this London Plane?
    I originally thought I'd bought a piece of walnut so I was aiming for a dark colour cabinet and I have bought a piece of lighter wood for the front panel for a contrast.
    Like this really Trainwreck
    flanging_fed “
    edited February 22 tFB Trader
    Plane will stain but you have to watch the colouring. As it has red in it. A dark brown may actually work. We use Osmo oil a lot at work. Osmo Thin will make it go darker.
    I have a pic here of someone who ebonised some plane.
    https://i.imgur.com/PSu5AWB.jpg
    And @SteveRobinson did a guitar with a plane top..
    https://i.imgur.com/R1IjaKQ.jpg
    https://i.imgur.com/Hq4hioq.jpg
    https://i.imgur.com/qRMijpt.jpg
    That ebonised looks amazing! Thanks
    flanging_fed “
    I might try Monty's Espresso Wax on the cab to darken it.
    flanging_fed “
  • elstoofelstoof Frets: 2749
    I’d be wary of darkening it, purely because your boards are made up of 5 or 6 pieces. They’ll each take the dye differently, very difficult to keep it looking like a uniform board
  • WezVWezV Frets: 17413
    I wouldn't, at least not without testing on scrap first.
    If you want a wax finish, direct stain first then wax will be more consistent.   Don't start with a wax based finish unless you know it is going to work the way you want.  It makes it hard to try anything else afterwards.
    That is actually a very good point.
