They did the opposite of copy, they made their own design.
So you tune it up and assume initially all okay. So what causes it to go out - just regular playing - big bends - or using the trem
is it all strings going out - are they going sharp or flat
just wondering about the Trem set up - look at the belly of the guitar and the base of the trem plate and they should be on a similar parallel line - Certainly don’t want the trem plate angling up like a ski slope or down like a hill - so update accordingly on the above and let’s take it from there
Have you recently changed to a heavier string gauge?
D'Addario Balanced Tension 10-46 string sets come with a 13.5 thou B string. I recently put a set on a friend's guitar. The B was catching in its nut slot. A quick rounding with a slotting file cured the problem.
How old is your PRS CU24? The gears inside the Schaller "wing collar" machineheads eventually become sloppy.
The whole point of a PRS is that it stays in tune
The PRS six-screw fulcrum vibrato cannot match Floyd Rose motorcycle starting up stunts for very long without going out of tune.
Perhaps Rusty Strings
Are the tuner key screws overtightened? PRS do that. Release the tension slightly so the little spring washer between the key and the tuner body has a tiny bit of give in it.
