Thanks very much for that valuable feedback, and confirms that (although it's a supper little unit) unfortunately it can't do what I need. Even its big brother has dreadful switching issues.
However I did have a query about the 3 stomp box display at a time theme. Can you choose which ones to appear in the first 3 screens irrespective of the pedal chain order, demoting the ones you're less likely to need to 'stomp off' in the second batch of three. Or are they displayed purely in pedal-chain order?
Well, I'm impressed with the G3X so far. For crunch amp sim, I seem to have settled on the Bassman into the Revo-1 4x12 cab (in spite of going through a hi-fi power amp into two 1x12 V30 cabs). Got one of the compressors at the start of the chain and then the parametric EQ into the amp sim. Using external wah and drive before the G3X, and stereo tremolo, delay and reverb after. Good crunchiness for chords and excellent tone with my 'creamy lead' patch on the Nova Drive.
I haven't really played with the internal dirt pedals other than the Metal Zone one, which seemed okay but only has a single tone control (so not really a proper emulation). Sounded metalish, but I didn't spend much time with it. Same with the delays and reverbs, and the various combined pedals. I did have a fiddle with the conventional modulation pedals. The phasers, flangers and choruses all seem pretty good (speaking as someone that very rarely uses these sounds). I quite like the autowah as well.
The pitch shift effects were a bit of a mixed bag. The ones that can bend with the pedal seemed okay with lower notes but went weird with the highs (or maybe I'm just a scrappy player and was feeding it crap). The octave dropper does a passable bass guitar for messing around with, but again seemed to work best with the lower three strings. I thought the harmony effect was the best of the pitch shift effects - you can set the key and the interval, and it seemed to track well with tidy playing.
The drum box is rudimentary but quite usable for farting about. Haven't played with the looper yet. The wahs are a bit rudimentary (no Q setting, it seems), but I'd like to try one with the Nova Drive on to see what I think of post-distortion wah.
Agreed on the awkwardness of the patch changes - you can either do a two-button twiddle by bending down and using the little buttons on the top, or use the footswitches. Not really an issue for me, since I don't really need to change quickly. If it can be made to accept MIDI patch changes with an adapter, then that with a MIDI switchboard would seem to be the obvious remedy.
One thing that I do find a fiddle is scrolling through the various effects when setting up a chain - there's loads of them, and it's easy to go in the wrong direction. I noticed that the patch name editor has a dial that lets you jump between groups of characters (upper case, lower case, numbers, miscellaneous chars). It would be good to have something similar to jump between groups of effects. Not a terribly big deal, though, since the effect scrolling is only really done when setting things up.
Overall, so far, a most impressive piece of kit. For me, the amp sims and EQ make it worthwhile - the general tone is pretty much transformed (power amp is a valve hi-fi job with no EQ and a dead flat response). Getting a huge pile of modulation effects and dirt boxes is almost a bonus (even though I'll probably never use most of them), as is the looper - I've been musing on getting a looper recently.
Nomad
It's no hassle to set up either, as the G3 is USB powered you just plug it in and the software autoruns.
Band Stuff: https://navigationofficial.bandcamp.com/album/silhouette-ep
Nomad
Nomad
