Incoming NPD- serious delay
  • Incoming NPD- serious delay in Gassage's feedback on it.
  • Give a man time. He's got to figure out what to trade it for before he does anything silly like writing a review :D
  • GassageGassage Frets: 31080
    Well, it's AWOL. It's been delivered to one of my neighbours and I can't find it....grrrr.
    As I typed that it arrived !!
    Will plug in now...
    it's very complex...!
    Much smaller than it looks too!
    OK after fiddling with it for 20 mins, it's bloody lovely. I suspect, once I've worked out all the functions, it's a bit of a game changer....the BPM corrector is stellar!
    What is the BPM corrector?
    edited November 2014
    OK- so let's say you think you need 470ms for a certain song...so you start playing it and maybe it's played at 440ms because your drummer can't keep time- it corrects the delay times to the cadence of your playing. Seriously.
    (you can bypass it thankfully)
    hmmm, strange... don't see why you'd want that if you've got a tap switch.
    Because when you tap something in you're not always very accurate- so it takes your tap time, and then increases or decreases by +/- 20% depending on the timing of what you're playing. Neat.
  • monquixotemonquixote Frets: 17851
    It's got a little microphone in it so I think the idea is that you tap in at the start and if the drummer wanders off tempo the delay pulls it back in.
    It's got a little microphone in it so I think the idea is that you tap in at the start and WHEN the drummer wanders off tempo the delay pulls it back in.
    Fixed for you.
  • allicioallicio Frets: 221
    The timeline sounds better on the demos ive seen there isn't much point in asking your opinion on that I assume!!!!
    Maaaan there is NO comparison. Honestly. One sounds like a delay. The other sounds like a delay with a sock over the speaker.
  • randomhandclapsrandomhandclaps Frets: 20521
    This is not a line Gassage uses often on the internet.
    @randomhandclaps
    You fucked the punchline there old boy..!
    I bloody well am!!
  • Gassage said:
    @randomhandclaps
    First time using a tablet device. It's all a new experience for me...... Which yes, is a line I use often on the internet.
  • Paul_CPaul_C Frets: 7910
    I'd nearly convinced myself that I could be happy with a Vox Delaylab. . .
    It's actually not as difficult as I first thought to programme- however, the buttons are so small I need my reading glasses to see them- so how you'd do it on the fly on stage is beyond me. Lush pedal though- I still like the chrono mind you...
