Incoming NPD- serious delay in Gassage's feedback on it.
Will plug in now...
it's very complex...!
Much smaller than it looks too!
(you can bypass it thankfully)
Because when you tap something in you're not always very accurate- so it takes your tap time, and then increases or decreases by +/- 20% depending on the timing of what you're playing. Neat.
Fixed for you.
This is not a line Gassage uses often on the internet.
You fucked the punchline there old boy..!
First time using a tablet device. It's all a new experience for me...... Which yes, is a line I use often on the internet.
