Build thread: Pancake body les paul deluxe
  • This is looking really really good, so impressive. Mahogany Les Pauls are possibly my favorite looking guitars too.
    Looking forward to seeing this finished in the new year.
  • That's looking very good @WezV   :)
  • WezV said:
    this is the closest I have done to proper carved top set neck les paul
    That looks ace. Got any more pics of it?
  • WezVWezV Frets: 16750
    <snip>
    yeah.  that one was a one peice mahogany body and totally carved by hand.  It was built for a mate  who likes heavy guitars.  His other two instruments where an SG2000 and 90's les pual studio - this was his lightest guitar at 11lbs.  His name was Twisty, which is why it has a twist in the neck ;)   He died about a year after it was made and I don't feel like it was ever finished - we tweaked it regualrly up until he passed and had ideas for other mods
    the original block of woodimage
    and an assembly shotimage
  • Lovely. Strange too – as I don't like the look of PRS guitars generally. Maybe it's down to all those fancy finishes. Just not my cup of tea. But I love this.
  • SambostarSambostar Frets: 8745
    Pics of your sanding tool re-enactment or it didn't happen.  Like porno, give us some slow motion detailed pics of the angles and what tools you used.  We need to learn dude. This is amazing.  Vaguely.  It is.
    Backdoor Children Of The Sock
    I didn't take pics, I just started sanding with the power sander and 40mins later it looked like this. I have linked to some threads which show the process in more detail.
    I put some masking tape around the edge and on the neck angle plane to save sanding there. I used a belt sander belt which I had previously chopped up - heavy duty clothed backed abrasive
    Easier and quicker than I thought it would be
    Or are you suggesting I am doing a dalefty and photoshopping the whole process. ;)
    No, I am suggesting you are a space alien and it happened with divine intervention.
    Besides You still have all your fingers.
    I didn't expect it to work as well as it did, which is why I was prepared to break out the proper tools
    As far as I am aware original gibsond were rough carved on a duplicarver before being taken to a slack belt sander for final shaping.  I guess this method is quite close to that, in a more DIY sense, so I shouldn't be surprised it gave a pretty convincing les paul style carve.
    The other thing it helps to explain is gibsons variable neck angles.  I hardly touched the neck angle plane  I had routed at 4.3 degrees when sanding the carve in, but I think I have still managed to change it to 4.1 degrees.  That must be much easier to acidently alter if sanding the contours on a slack belt sander.   I need to check again when I get home.  It won't affect the neck angle on mine as much as it would a gibson because I am doing a full width tenon so the bottom of the slot I route will determine neck angle, not the top of the body like on a normal gibson
    okay - rechecking neck angles.  I am using a spirit level on my phone for this. I am using my crappy work phone to take pics
     since mine is in the pics
     I used the same thing to determine the angle i set my router thicknesser jig to for cutting these angles
    First thing though, better check I am on a level surface
    0.2 degrees - i will take that off the actual measurements
    Neck angle plane - (4.39-0.2) 4.19 degrees
    Pickup angle plane (1.59 - 0.2)  1.39 degrees
    and it levels of at the bridge
    I was aiming for 4.3 and 1.5 degrees so I am pretty happy with that after sanding
    0reaction image LOL 4reaction image Wow! 1reaction image Wisdom
    turned my attention towards the neck tonight.   If you remember its a 3-piece mahogany blank I had squared up and cut the headstock angle on.   No progress pics  - but here was the order of operations tonight
    The starting point - a nice square blank all marked up.   There is actually an error in my marking i should have picked up - but its not an issue and I will show it later
    First step then, whilst still square is to route for the truss rod.   I do a square bottomed channel with a 1/4" bit for most of the length, then finish off the last section with a 1/2" round nose bit to give a nice access channel
    Once that was done I went to the bandsaw and cut out the side profile.   should have double checked this, i left the heel far too long so will need to go back and cut a bit more away later... no bother.
    Once the side profile was cut out i got out the router thicknessing jig again and routed the underside of the heel to be perfectly flat and parallel with the face of the neck - the neck heel won;t be angled, but the slot in the body will be to give us the neck angle
    then I got some straight edge templates, marked the top of the neck blank again and routed down either side
    and that's where we are now
    truss rod is a nice push fit -
    fretboard fits on top perfectly - you can see the long heel
    so that's quite a bit done.
    next steps:
    • Cut heel back a bit
    • (I may taper the neck thickness on the router thicknesser, or may just do it at caving stage)
    • Add headstock wings
    • Veneer headstock
    • Thickness back of headstock
    • Cut headstock shape
    • glue fretboard
    • carve neck
    • fret
    • fit to body.....
    Got the neck heel cut back a bit closer to the body join and glued on the headstock ears tonight.
    Small progress, no pics
    edited December 2015
    so neck is now cut to its actual shape and I have gone a bit off piste.   I am trying to decide whether to celebrate the mahogany  by leaving the headstock plain, or just veneer it  i decided to get it all cut to shape to see, may still veneer it later
    anyway - side profile fully cut out
    headstock shape cut
  • SkodadadSkodadad Frets: 509
    Impressed as ever, you talk about building guitars like it's buttering bread!
    and the headstock shape
    I sometimes struggle to butter bread - i get really frustrated when the bread tears!!
    5reaction image LOL 0reaction image Wow! 2reaction image Wisdom
  • impmannimpmann Frets: 12669
    You see, I had this brilliant idea for spray butter for that exact reason - much like squirty cream - but I was told nobody would buy it.
  • I like the idea of the headstock matching the plain wood body.
