Behold my massive board of pedals
1197198200202203393
  • JEPBLEPJEPBLEP Frets: 188
    Ps. I’d love to see a signal path
    Ditto - amazing boards!
  • TimmyOTimmyO Frets: 7419
    JEPBLEP said:
    In all seriousness though - that's reasonably tidy - are the purple lines carrying signal though? You probably don't want to strap those up with your power lines though right?
    Having said that, if it works, it works! ¯\_(ツ)_/¯
    It's only 9v, and the signal cables are screened.
    Power noise comes from shared earths, DC leakage, noisy (electrically and electromagnetically) transformers rather than a few mA at 9v running close to screened signal cables.
    Red ones are better.
  • Great grab and go setup
    LOL! I am aware it' ridiculous! But it keeps me amused while cranking out the same covers night after night!
    You play covers with that :open_mouth:
    are you single? How do you get your missus to let you away with this? Please give tips
    I have a very supportive wife who also does booking management for the band! She understands my sickness and sells it to punters that we are able to get the most authentic sounds bless her!
  • MikkiMcMurdererMikkiMcMurderer Frets: 352
    edited January 2018
    OK here goes:
    The main principle is redundancy for live, so there are multiple paths to the amp / PA in case of problems.
    Wireless (Stageclix) into the Whammy (so can use detune function on all signal paths) and then into a Radial Shotgun under the shelf on middle board that splits the signal 4 ways with buffer and ground lift.
    Path 1 goes to the main board on left with all the main pedals
    Path 2 goes to back up pedals on middle board shelf
    Path 3 goes straight to the amp
    Path 4 goes to the Zoom A3 for acoustic line out
    Paths 1,2 and 3 get recombined with the Gigrig 3to1 and then out to a Keeler loop switch that is a send and return to the TC G Major 2 rack and then off to the Orange OR100 amp.
    So path 3 only has the Whammy and the rack loop switch in the signal path before the amp.
    To be continued....
    edited January 2018
    The first output from the Radial goes:
    Digitech Freqout
    Digitech Ricochet
    CAE Wah
    MXR TalkBox
    Cinco Cinco to left board
    Keeley loop pedal that can bypass the left board
    TC Tuner
    G String Decimator that has all distortions in loop
    Xotic SP compressor
    Input of Bright Onion 20 loop switcher
    Loops:
    1. Digitech Synth Wah
    2. MXR Micro Flanger
    3. Mooer Elec Lady
    4. MXR EVH Phase 90
    5. Boss CE2
    6. Earthquaker Arpenoid
    7. Wampler Tumnus
    8. Ibanez Keeley modded 808 TS
    9. HAO Rust Booster
    10. Timmy
    11. 4114 FX Red Snapper clone
    12. ZVEX Box of Rock
    13. RAT 2
    14. OCD v4
    15. MI Crunch Box to be replaced with JHS AT
    16. Basic Audio Scarab
    17. ZVEX Fuzz factory
    18. Mojohand Iron Bell
    19. Dr Scientist Elements
    20 Wampler Sovereign
    Exit from 200 loop switcher to loop return of G String
    Boss DM2W
    Eventide H9 max with Barn switcher
    Xotic EP booster always on
    ZVEX Super Duper 2 in 1 boost side always on
    Award Session Solo Boost
    Source Audio EQ
    Keeley loop pedal return and back out to Cinco Cinco
    It then crosses over to the right side board if that is plugged in (it can just be jumpered with the Cinco Cinco if not in use)
    1reaction image LOL 2reaction image Wow! 0reaction image Wisdom
  • The right side board is:
    Cinco Cinco in
    EHX Freeze
    Boss Flanger
    EHX Pitch Fork
    EHX Hog 2
    Line 6 Echo Park
    Strymon Timeline
    Digitech EX7
    The Mission XP pedal goes to the Mission Expressionator to control the TC Rack, The Hog and The Timeline
    The signal goes back via the Cinco Cinco to the middle board to finally go through the
    Fulltone MDV3
    GigFX Chopper
    The it ends up at the Gigrig 3to1
  • Path 2 goes:
    Rainger FX Fuzz
    Maxon ST9Pro
    Dod Caracosa
    Gigrig 3to1
    The Amp channel switcher is between the Maxon and Dod
    Path 3 goes straight to the Gigrig 3to1
    Path 4 straight to Zoom A3 if playing acoustic or a piezo bridge
  • Gig Rig did all the power and setting up the middle and right hand boards (thanks Joe and Jake) and custom pedalboards made the ridiculous middle board wedge thing. Luckily I have a van that this all lives in flighcases for gigs.
    The Yamaha MFC10 controls the TC rack patches
  • TeetonetalTeetonetal Frets: 7802
    @MikkiMcMurderer i'm intigued. Guess from authenticity comment that you are doing a covers. May I ask which band?
  • tone1tone1 Frets: 5163
    Buddy Holly tribute band is my guess  :)
    edited January 2018
    www.superchargerband.com
    @teetonetal
  • TheMarlinTheMarlin Frets: 7864
    Mine has changed yet again.  Just awaiting arrival of Simble Pre Driver.
    https://imgur.com/a/NSeKf
    Thanks to @simonk for the new Pedaltrain (And the tea) A quickly thrown together shot before the School run...
    https://i.imgur.com/EJthvzt.jpg
  • simonksimonk Frets: 1467
    Ha! That was quick @tone1 ; Nice to finally meet you matey.
  • frank1985frank1985 Frets: 523
    TeeByrd said:
    What is that in the middle with the 4 switches?
  • sgosdensgosden Frets: 1994
    is that both the SI and GE version of veteran you've got there?!
    edited January 2018
    @sgosden  Guilty as charged
    Guitar > Carl Martin tuner > Thorpyfx SI Veteran > Thorpyfx Germanium Veteran > Lazyj Cruiser Deuce > Palmer Solid Metal > EHX Small Stone Phaser > TC SCF Chorus > Providence Chrono Delay > Jrockett Boing Reverb...
  • ricorico Frets: 1220
    This is my latest revision, I took off the Guv'nor in favour of a Bluesbreaker/POT which seemed more appropriate for the gigs we have lined up.
    Signal chain is as follows: (Crybaby) -> TU-3 -> Fuzzdog EP boost -> Fredric Effects POT -> Odyssey -> Klone -> OCD -> Carbon Copy -> HOF mini
    Powered by a Fuel Tank Jr, wired up with solderless cable (apart from the last patch cable, I ran ouf of plugs).
    Very happy with this iteration. The combination of EP boost, Odyssey and Klone is just brilliant with a tele.
  • WazmeisterWazmeister Frets: 9534
    Mini board for a mini gig...
    Only 4 songs tomorrow;
    - That's Entertainment
    - Different For Girls
    - I Can't Explain
    - It's Only Natural
    Sometimes, simple is best.
    Rickenbacker 360/12 WB, Mini Board, (borrowed) Fender Supersonic.
  • garfygarfy Frets: 144
    - I Can't Explain
    - It's Only Natural
    Class!!
