Power noise comes from shared earths, DC leakage, noisy (electrically and electromagnetically) transformers rather than a few mA at 9v running close to screened signal cables.
The main principle is redundancy for live, so there are multiple paths to the amp / PA in case of problems.
Wireless (Stageclix) into the Whammy (so can use detune function on all signal paths) and then into a Radial Shotgun under the shelf on middle board that splits the signal 4 ways with buffer and ground lift.
Path 1 goes to the main board on left with all the main pedals
Path 2 goes to back up pedals on middle board shelf
Path 3 goes straight to the amp
Path 4 goes to the Zoom A3 for acoustic line out
Paths 1,2 and 3 get recombined with the Gigrig 3to1 and then out to a Keeler loop switch that is a send and return to the TC G Major 2 rack and then off to the Orange OR100 amp.
So path 3 only has the Whammy and the rack loop switch in the signal path before the amp.
To be continued....
Digitech Freqout
Digitech Ricochet
CAE Wah
MXR TalkBox
Cinco Cinco to left board
Keeley loop pedal that can bypass the left board
TC Tuner
G String Decimator that has all distortions in loop
Xotic SP compressor
Input of Bright Onion 20 loop switcher
Loops:
1. Digitech Synth Wah
2. MXR Micro Flanger
3. Mooer Elec Lady
4. MXR EVH Phase 90
5. Boss CE2
6. Earthquaker Arpenoid
7. Wampler Tumnus
8. Ibanez Keeley modded 808 TS
9. HAO Rust Booster
10. Timmy
11. 4114 FX Red Snapper clone
12. ZVEX Box of Rock
13. RAT 2
14. OCD v4
15. MI Crunch Box to be replaced with JHS AT
16. Basic Audio Scarab
17. ZVEX Fuzz factory
18. Mojohand Iron Bell
19. Dr Scientist Elements
20 Wampler Sovereign
Exit from 200 loop switcher to loop return of G String
Boss DM2W
Eventide H9 max with Barn switcher
Xotic EP booster always on
ZVEX Super Duper 2 in 1 boost side always on
Award Session Solo Boost
Source Audio EQ
Keeley loop pedal return and back out to Cinco Cinco
It then crosses over to the right side board if that is plugged in (it can just be jumpered with the Cinco Cinco if not in use)
Cinco Cinco in
EHX Freeze
Boss Flanger
EHX Pitch Fork
EHX Hog 2
Line 6 Echo Park
Strymon Timeline
Digitech EX7
The Mission XP pedal goes to the Mission Expressionator to control the TC Rack, The Hog and The Timeline
The signal goes back via the Cinco Cinco to the middle board to finally go through the
Fulltone MDV3
GigFX Chopper
The it ends up at the Gigrig 3to1
Rainger FX Fuzz
Maxon ST9Pro
Dod Caracosa
Gigrig 3to1
The Amp channel switcher is between the Maxon and Dod
Path 3 goes straight to the Gigrig 3to1
Path 4 straight to Zoom A3 if playing acoustic or a piezo bridge
The Yamaha MFC10 controls the TC rack patches
@teetonetal
https://imgur.com/a/NSeKf
https://i.imgur.com/EJthvzt.jpg
is that both the SI and GE version of veteran you've got there?!
Guitar > Carl Martin tuner > Thorpyfx SI Veteran > Thorpyfx Germanium Veteran > Lazyj Cruiser Deuce > Palmer Solid Metal > EHX Small Stone Phaser > TC SCF Chorus > Providence Chrono Delay > Jrockett Boing Reverb...
Signal chain is as follows: (Crybaby) -> TU-3 -> Fuzzdog EP boost -> Fredric Effects POT -> Odyssey -> Klone -> OCD -> Carbon Copy -> HOF mini
Powered by a Fuel Tank Jr, wired up with solderless cable (apart from the last patch cable, I ran ouf of plugs).
Very happy with this iteration. The combination of EP boost, Odyssey and Klone is just brilliant with a tele.
Only 4 songs tomorrow;
- That's Entertainment
- Different For Girls
- I Can't Explain
- It's Only Natural
Sometimes, simple is best.
Rickenbacker 360/12 WB, Mini Board, (borrowed) Fender Supersonic.
