Baja Tele refinish - Finished - Pic heavy!...
  • Winny_PoohWinny_Pooh Frets: 7769
    Yeah, was looking too patchy and uneven.
  • poopotpoopot Frets: 9099
    Didn’t mind that tbh.... just the sheer orangeness was getting to me :)
    In the words of Paul Rodgers:
    ”All White now”
  • munckeemunckee Frets: 12359
    That looks really nice.  BBQ looks a quality bit of kit too.  I'll bring beer : )
    Can just imaging what the Mrs would say if I said a load of guitarists were coming over!!!!!
    to tint or not to tint that is the question!!!
  • IvisonGuitarsIvisonGuitars Frets: 6838
    A light tint I say, just knock a little of the whiteness off it...
    http://www.ivisonguitars.com
    (formerly miserneil)
  • DanielsguitarsDanielsguitars Frets: 3290
    edited June 2018 tFB Trader
    well you already know what i think, it looks much better
    www.danielsguitars.co.uk
    (formerly customkits)
    Leave it like that and get a tortoiseshell guard
  • TheMarlinTheMarlin Frets: 7862
    Much better in white.
  • GoldenEraGuitarsGoldenEraGuitars Frets: 8823
    Coating blonde in an aged tint can yield some very satisfying results
    https://i.imgur.com/ohoDsT5.jpg
    edited June 2018
    I have a tinted clear winging its way to me... my worry is that I get a patchy or uneven finish... I have been assured tho’ that even a ham fisted gimp like me will be ok!.
    any advice on stripping a poly neck? Don’t really need to refinish it but I think once the body has had some aging the poly neck going to look a little out of place!...
    edit- ps, got a full refund on the boat anchor in the end :) and just repaired the body existing body!...
    edit- ps, got a full refund on the boat anchor in the end and just repaired the body existing body!...
    The idea is not to get a uniformed look. It keeps it looking natural. The only thing I will say is I never do equal or even coats with my tinting.
    Yip...
    1. Buy a pack of Stanley blades
    2. Put some good tunes on
    3. Pour yourself a beer
    Your best bet is to scrape that poly off. It’ll take a while but it’ll be worth it
    Good call on the body, I’m glad you got it sorted.
    lonestar said:
    Youre best bet is to scrape that poly off. It’ll take a while but it’ll be worth it :)
    Was afraid you were going to say that :/
  • WezVWezV Frets: 16671
    Point 1 is the most important bit.  You can do it with 1 blade but it will get hard going and you are more likely to cause damage.
    Change for a fresh blade regularly.
    Definitely. And if you don’t go through 5 blades in the process you’ll end up sanding out scratches for a year.
    This is the one I’m overhauling just now...
    https://i.imgur.com/6gy0kZW.jpg
    https://i.imgur.com/uvYKwvf.jpg
    https://i.imgur.com/73mwKzE.jpg
    https://i.imgur.com/kP1Rf9w.jpg
    And yes, it was given a full fret dress!
    https://i.imgur.com/TRpQVi4.jpg
    Currently drying out before wet sanding, buffing and ageing.
    The took a lot of time to strip but it’s looking good with a little reshaping too.
    First coat of “butternut squash” done....
    Better?
  • lovestrat74lovestrat74 Frets: 2526
    On the neck front mine went from this:
    To this via a lot of blades.. (you can see the diff as in this pic the headstock was yet to be done)
    Feel the pain, this was/is not a fun job...
    Yeah, thinking I may give that a miss!... :)
    Ok... think we are getting somewhere now...
    body painted, doesn’t look quite right with the Bakelite guard tho’
    Body is a bit too too pale to pull it off.. so a callaham parchment guard was blagged from the bay... looks better with white methinks...
    In the meantime @TheGuitarWeasel wound me a rather lovely looking pickup for the bridge and I managed to find something I remember being a bit special in the shed...
    Just got to bolt it all back back together now!!!
    Looking really good.  I miss the slutty ginger though! : )
