Which (if any) delay do I want?
monquixotemonquixote Frets: 17942
edited September 2014 in FX tFB Trader
My Carbon Copy is about to go winging it's way off to a new home.
I liked it, but it's just a little too dark for me.
I'm starting to wonder if I just don't like delay, but I thought that about compression until I found the SP Comp.
So far I've tried:
EHX Big box DMM - Perfect sound, but too big and too unreliable
EHX Memory Boy - Loved it for wobbly lushness, OK as a regular delay, should not have sold it.
Mad Prof Deep Blue - Liked it a lot, slightly too bright, no mod, and worked better with distortion than with clean sounds
Zoom G3 - Some good sounds, but too big and I can't get on with the workflow
WH Aqua Puss - Amazing sounding delay, but delay time too short, box quite big and not enough delay time
MXR Carbon Copy - Repeats too dark, but otherwise very good
TC Alter Ego - Too many options for live use, but sounded fairly good.
Features I need are:
About 600ms of delay (I don't want a delay with 4 seconds of delay on a pot as they are impossible to dial in)
Analogue type repeats though not too dark (ideally configurable)
Form factor ideally MXR sized or WH/Strymon Sized if it has top mounted jacks
Ideally some mod preferably on a toggle
Things that are on my try list are:
Echo Puss or Supa Puss
Strymon El Cap - Probably too expensive for something I don't use that much
Thomann Exclusive T-Rex Delay - Seems to be a mega bargain
EHX Tap Tempo DMM - Again waaaaay too expensive
Malekko Delay
What else should I be looking at?
«134
  • My Carbon Copy is about to go winging it's way off to a new home.
    So far I've tried:
    Malekko Delay
    You're almost describing the Boss DM-2 Waza craft to a tee there.
  • JalapenoJalapeno Frets: 6424
    Tried a TRex Reptile ?
    Some other thoughts .... http://www.joespedals.com/acatalog/delay.html
    How about getting a modded MXR ?
    Feedback
  • EricTheWearyEricTheWeary Frets: 16453
    Never seen a Supa Puss before. I might be in love. T Rex Replay? Straightforward and fairly compact, although I get the impression it is fairly digital sounding. I have been watching Minifooger Delay videos but I think you'd find it too dark. I like that you can boost the signal, has expression pedal out ( so does the Supa Puss) and it looks nice ( in an industrial sort of way). Budda Samsara has 600 ms and tone control over the delays, it's a pretty colour and relatively cheap. No tap tempo but then you don't seem to be looking for that. EDIT: no modulation on the Budda so probably ignore that. Unless you really like the colour.
  • hugbothugbot Frets: 1528
    I dont get how the TC electronic pedal had too many options, surely you just find a setting you like and leave it there? I never moved it off tape.
  • monquixotemonquixote Frets: 17942
    Because it get's kicked and that means that it will suddenly be on some mental reverse feedback delay when I kick it on and the labels are too small for me to see standing up.
    Also it had too much delay time on the knob making it hard to dial in.
    edited September 2014 tFB Trader
    I've been pondering this T-Rex which seems a mega bargain for £66
    http://www.thomann.de/gb/t_rex_play_back.htm
    So far I've tried:
    Malekko Delay
    buggery bugger, I want one of those now. No modulation for the OP though?
  • RaymondLinRaymondLin Frets: 12064
    Seymour Duncan Vapor Trail, I really want to try one.
    Check out Premier Guitar's demo.
    http://www.seymourduncan.com/pedals/vapor_trail_analog_delay/
    Delay Range: 15ms to 600ms. Actual delay time indicated by flash rate of illuminated delay time knob.
  • KebabkidKebabkid Frets: 3356
    A Boss DD3?
  • I have a Mojo Hand Recoil Delay which I have just swapped out (ironically enough) to put a Carbon Copy back on my pedalboard. The Recoil is an analog-voiced digital delay and has 550ms of delay and has a very handy tone knob to darken/brighten your repeats depending on the situation.
    +1 for that bugger....there was me thinking I was pedalgasfree, I forgot about those!
  • Catalinbread Echorec
    You can run it in "single head" mode, so it's not all about the multi-tap weirdness.  Lovely modulation (no external toggle, though), adjustable tone on the repeats, sits behind your natural/dry signal really, really well.  I love it, and this is coming from a confirmed Floyd agnostic.
    New fangled trading feedback link right here!
  • I have the Behringer near-copy (clone of a DM-3 I believe). Even for less than £20 it's great.  So for that reason I really, really want to get the Waza craft.
  • I've heard very good things about the Vox delay lab thing. I have an Empress SuperDelay which is also incredible.... Pricey though, especially on these shores
    I'm a bit wary of some of these delays costing £200 as I'm not really a heavy delay user, but I wonder if the reason I'm not is that I don't have a really nice delay pedal.
    The delaylab is hooge though. What about the new seymour duncan one with modulation?
    Vapour Trail is like almost half that.
    http://www.thomann.de/gb/seymour_duncan_vapor_trail_analog_delay.htm
  • I have some very nice delays, but the DD20 remains the most convenient one on my board. I do have a board the size of an average to large dining table though.
    That could be a winner.
    It's both tiny and has top mounted jacks.
  • TC Electronic Flashback mini. Three knobs, one toneprint.
    You know you can edit the minimum/maximum delay time on the knob ucing the Toneprint Editor? Maybe a bit of toneprint tweaking to get what you want but, once done, it's a straightforward three knob delay adjusted perfectly for your needs.
