What's your favourite analogue delay pedal?
equalsqlequalsql Frets: 6235
in FX
I love warm analogue delays. I used to own a Carlsbro Echo many years ago that I foolishly sold on. I also really loved the Red Witch Violetta, it having a gorgeous modulation, but using a rechargeable battery I decided to avoid, cos getting a replacement later on down the line would be problematic.
I've got a cheap Mooer which is OK but would like something a bit better and warmer.
Do you folks have a particular fav analogue delay that is your goto?
«13
  • pt22pt22 Frets: 319
    I only have experience with my MXR Carbon Copy but it fits the mold. Analog. Warm. Iconic. It’s a great pedal.
  • stickyfiddlestickyfiddle Frets: 27697
    Soundwise mine is the Asheville ADG-1. Utterly gorgeous thing. If it had tap tempo I doubt I'd ever look at another delay again
    (I mean that last part is definitely not true, but it's really good)
  • LebarqueLebarque Frets: 3962
    Boss DM-2 Waza
  • Winny_PoohWinny_Pooh Frets: 7889
    For short times an old dm-2 or ad-9
    For longer times a Delay Llama Xtreme or the Supro. I own both.
    Carbon copy & vapour trail a bit dark.
    Not tried a dm-2w
  • KDSKDS Frets: 222
    Original Boss DM-3
  • UnclePsychosisUnclePsychosis Frets: 13036
    DM-2W or Way Huge Aqua Puss
  • digitalkettledigitalkettle Frets: 3357
    Benson.
  • JezWyndJezWynd Frets: 6171
    Carbon Copy Mini and Carbon Copy Deluxe. Both have the Bright setting which makes an already fabulous delay perfectly perfect (fect, fect fect...)
  • DoctorXDoctorX Frets: 393
    I’ve got an Asheville ADG1-SE and a Strymon Brig. They’re both great. The Strymon isn’t technically analogue, but sounds like it is. If I was forced to get rid of one I’d probably keep the Brig due to ease of use and extra features (stereo, multi mode, midi presets/tap)
    edited May 3
    Benson.
    I've been wanting to try that one but I'm slightly put off by the early onset of feedback. He says he wanted the spaceship noises to be a feature but there's only so much you can do with that sound and I've yet to hear it used to any great musical effect.
  • tomajohatomajoha Frets: 927
    +1 for DM-2W, DM-101 is also great but goes beyond my needs
  • gatheredinsonggatheredinsong Frets: 678
    The Mythos Oracle does exactly what I need and is my go to, can't beat the simplicity of it's functionality. I will buy the Asheville at some point though!
    JezWynd said:
    Benson.
    It lives with all knobs around 9 o'clock...then tweak to taste...it's quite lively with anything above noon but it can be beautifully subtle too.
  • Matt_McGMatt_McG Frets: 328
    I like the Skreddy Echo, which isn’t technically analogue (it’s a PT based delay) but it sounds analogue and has some clever limiting to keep the oscillation and repeats in check when you crank it.
  • ElectricXIIElectricXII Frets: 1197
    I love my Belle Epoch. It sounds analogue, even if some of it is digital.
    edited May 3
    Benson is analog-sounding-digital fwiw - same chips as the Skreddy and EQD Disaster Transport.
    Sounds bloody good though
    Oops ;)
    geeks!
  • slackerslacker Frets: 2275
    Mine are both unobtanium. Large box dmm best delay ever and number 2 the analogman ar.
  • timbuk02timbuk02 Frets: 273
    edited May 3
    This looks nice but not out just yet...
  • Jonathanthomas83Jonathanthomas83 Frets: 3492
    I have the Strymon Brig and love it to bits. Also have a little XVive Echoman which gets crunchier and I love that, too. I had an Asheville ADG-1 up until recently and loved it but it's very clinical as far as analogue delays are concerned. The aforementioned lean further towards the DMM end of the spectrum than the Asheville end, and that's probably why I chose to keep them and sell the ADG-1.
    Very interested in this!
