Feedback
Please let us know here of anything you find that doesn't work properly and any suggestions for new or improved functionality.
There is a 2-week cooling off period during which we won't be adding any of the latter but will be working on the former.
Also please note that for the moment you can post in existing discussions here, but can't edit or delete posts nor make new discussions - this is just because we need to keep Meta as clear as possible so things don't get lost - hope that's OK with everyone. :)
«13456730
  • SporkySporky Frets: 28828
    Quoting - if you hit the " then you go to a different page. If you click the word "Quote" then all is good.
    Badges - need to update the badges to match the Reactions icons.
  • TTonyTTony Frets: 27736
    Default state of the comment box for iOS devices (ie show source).  Can we change it to "show rich text"?
  • digitalscreamdigitalscream Frets: 26825
    While I'm thinking about it...we need a default thumnbnail for Facebook (when somebody posts a link to the forum, you can force it to pick a specific image for the thumbnail). At the moment, it doesn't show anything.
    I can make the appropriate changes to the HTML, but we need an appropriate logo image first :)
    <space for hire>
    @ddlooping - can you make an appropriately sized version of the Favicon mebbe?
    We *should* have a theFB logo.
    Just been thinking about that on the "let's build us a guitar" discussion.
    Open compo to design one???
  • ddloopingddlooping Frets: 325
    I'm up for it. :)
    Do we know what size the thumbnail is supposed to be?
    It has to be square - I've found the best results with 200px or 300px.
    <space for hire>
    ddlooping said:
    I'm up for it. :)
    Denis - being "a creative" could you kick this off?
  • monquixotemonquixote Frets: 17702
    ChristophEar suggested using http://99designs.co.uk/
    Apparently you get very good results.
    edited August 2013
    £200? Not especially sure it's worth that much ;)
    <space for hire>
    Ooo actually that's quite expensive.
    edited August 2013
    Would the following do for now, until a proper graphic designer jumps in?
    Or...
    I like the second one best - it'll jump out more when Facebook thumbnails it.
    <space for hire>
    Ditto.
    Unless there are any objections in the next 10 minutes, I'll get on it with the second image. That OK with everyone?
    <space for hire>
    Fine by me!
  • Nice! I'd vote for the sizing of v2 but with the outline/shadow effect from v1.
    I'd also be inclined to add similar white text (with the full name) on the site's header logo.
    I know it does say "The Fretboard" beneath the image, but stronger branding never hurt. If people are hitting the site from search engines, they may only glance and it's worth making sure the name sticks in their visual memory...
    I personally think that the full name stays in the top navbar or goes on the header, but not both.
