I guess the tricky bit about bbq slow cooking is temperature management, making sure it doesn't get too hot (or lose heat).
Great news you enjoyed the weber, I find the chimney a great tool. I quite often do a chicken or pork and towards the end put an extra handful of coals in the chimney to top it up for direct cooking of sausages, meat, kebabs etc at eating time.
The black is a crust - not burnt!
I only get briskets and beef ribs from a butcher (Turner & George)
Local butcher, I try and use him when possible rather than supermarket. I ask him for skin and most of the fat off. I usually go for just over 2Kg which I think comes in under £20. I'll pay more attention to the price next time!
I finally have a garden so would be nice to get something for chicken, steaks and burgers.
Maybe also for finally touches.to briskets as well.
Your burgers, steaks etc will be great and for some relatively short low and slow like a pork shoulder it is also very good.
For a full pack brisket that might take 15 hours to cook the kettle is the wrong choice really as you'll be forever filling the damn thing up with fresh coal and trying to remove some of the spent stuff. Weber Smokey Mountain is a good buy for that sort of thing - but that's not great for grilling steaks and burgers. It can be done (like putting the grill right on the fuel ring) but it's not designed for it.
If you're only going to have one, go for the kettle - the biggest one - 57cm - that will allow space for indirect cooking.
Have a look on ebay - nothing wrong with a used Weber. They last a long time and a good burn in will kill anything the last owners left on it. You can get replacement grates if you really want to.
I really want to try a low and slow on mine, but being the only meat eater in my house means I don't get many opportunities. I did a marinaded rack of lamb last weekend which was one of the best meals I've done on it. Your standard burgers/sausages will taste the best they can too.
https://www.google.com/amp/s/www.riversidegardencentre.co.uk/weber-one-touch-original-57cm.html?amp=1
It was very nice. I tend to buy most of my meat online from John Davidsons, but their Boston butt’s start at twice the size of the Farmison’s one.
What do you do to get a nice bark on your pulled pork?
The briquettes burnt much longer than the half an hour it took to cook my meat n veg direct. So, next time, should I use less briquettes? Or can I get away with getting cheaper briquettes, if just doing a quick cook? I can see the benefits of the weber briquettes for longer indirect stuff, but for shorter, direct?
You can then knock the ash of and put them back in the chimney for another cook
Even with direct cooking get used to putting the lid on. Even for only a few minutes in between flipping it makes the cook more efficient. Then it's like an oven with some fire.
I can get my kettle to almost 600F using a fuel dome / vortex and 1 chimney worth and it still lasts for a long time with that heat (perfect for high heat chicken wings).
Fewer briquettes is always good - you can easily add a few more if needed.
Sometimes I buy cheaper ones for just doing burgers but they can be a bit dusty and take longer to get rid of any start up smoke. Not sure it saves me much money.
