1Q22 Challenge Downbytheriver 335 style from a kit with stains
  • Ditch the plastic - defo!
  • TTonyTTony Frets: 27625
    One thing I haven’t mentioned is that, disappointingly, there is no large access from the pickup routs - the electrics will have to go through the f-hole - I need to experiment with that to see what kind of loom will fit.
    Mini pots?
    If it's the same thickness as a 335, and ditto the f holes, then standard pots will fit fine but you may need the shorter version of the 3-way that switchcrsft make.   But push/pulls probably won't fit (or technically may, but will be pretty much impossible to get in)..
    There's a lot of Youtube watching and patience involved...
  • PhilKingPhilKing Frets: 1485
    Has it got a hole in the bottom side of the bridge pickup cavity, that's a way you can sometimes get things in there.  The sideways switch will also fit, but you might have to have the wafer side away from the pots.
  • westwest Frets: 996
    west said:
    its a shame as i have some spare locking rotomatic machine heads with ebony buttons that came off my 335 but ....
    Rats! How much?
    The Lollars are definitely on my radar but I think it depends how the build goes before I commit to that sort of spendy.
    Fletcher or Alegree pickups are worth a look for sensibly priced good quality pickups.
    I’ll take a look - same proviso as above.
    Meanwhile I’ve been out in the shed… very light sanding to the sides of the neck heel and another tight dry fit. I’ve laid a few parts in place and the neck angle looks perfect! That scratchplate won’t do though! Something else to think about.
    Brought all the wood inside the house - it’s a bit damp out there at the moment
    @downbytheriver ; £45 posted ppg they are chrome 106 18;1 rotos with black ebony buttons .... i dont have the 6 little screws as i used the ones on me 335 ... pm if interested and i can send a pic ... ;)
  • Stains arrived today - few days in quarantine then some experiments at the weekend I think. I’m getting too excited - must not rush.
    Rushing, my biggest problem….
    I’ve done so many quick jobs that turned into much (much) longer repair-the damage-and-do-it-properly jobs!
    Me too!
  • Another inspiration in Guitarist (thanks for the pic) - I really like this scratchplate idea (I really could not do a 335 without a plate) but where will I get that made?!?
    Ps. This is a Robson guitar - really interesting new brand from the people who make the posh machine heads
    Custom cooletch?
  • Custom cooletch?
    Perfect answer - thanks
  • WezVWezV Frets: 16733
    also check out indra guitars
    https://www.indraguitars.com/content/custom-pickguard#/
    I've done a few out of aluminum and a Dremel engraver, but rougher than a properly engraved example though
  • Wow that’s even better Wez!
    Wow! That looks absolutely incredible!
    I really like the custom cooletch stuff but it does look quite different to that indra...
    Bookmarked!
  • downbytheriverdownbytheriver Frets: 1049
    edited January 2022
    Looking at stains.
    I ordered a couple of bottles of the newish Crimson Guitars Pastel Stains - sky blue and sea foam green with the possibility of a blue green burst styley finish in mind.
    In the cold damp shed this morning I tried them out. The blue green burst doesn’t look right - probably needs bolder colours (especially the blue).
    The green alone is a possibility
    Any opinions?
    actually the blue green looks better here than it did in the shed!
    I like the blue green burst, subtle, could you apply more to make it less subtle if desired?
    edited January 2022
    Not really - just obscures the grain - maybe add a darker blue on the outside
    I like the blue green as it is
    Have you put any top coat on, m
  • Just a spray over with acrylic clear
