The ridge is still as high as the pickups, so i will probably take a few mm off the top of it and recarve the curve from there. worst case if i don't like it is i flatten off the whole section
Instagram
Back of the body has had an afromosia plate made, then both body and plate have been subtlely radiused
Headstock has been cut to a shape that's mostly ibanez in size and shape, with a different end.
Board has been radiused and nut slot cut
Body is just about ready for finishing. Think I'm going to try some milk paint for it, but will see how the test go.
Instagram
Like the headstock, such a tricky thing to get right but that looks really smart.
When I first saw people using it, it was all for shabby chic easy relic style stuff. But with people like millimetric and schorr guitars getting good solid colous on modern guitar styles I thought it could be worth a look for something like this.
Instagram
Neck has been inlaid with some pearl dots. Just need to glue a truss rod fillet in place before carving and fretting
Instagram
Instagram
https://oldfashionedmilkpaint.co.uk/collections/old-fashioned-milkpaint/products/providence
the instructions say to mix the powder 1:1 with water. This is what I did for the first coat, and it was a little thick. It also starts to gel up pretty quickly if you don't stir regularly.
This is one coat applied with a crappy brush. Its applied to raw wood
not a bad start for one coat on raw wood
It sands well and burnishes to a nice eggshell at 240g. feels pretty sturdy. Clean up is really easy with water
I'm going to build a few thinner coats and see what we end up with. I'm going to try a mini roller for application once i have a good solid base coat laid down. I might try spraying, not sure yet.
I'm currently thinking an oil based top coat will be best, mainly because it seems counter intuitive to overspray a traditional water based finish with lacquer.
Instagram
Instagram
Definitely a contender for me as well, if my mtn sprays don't work out. I've read some people use this stuff to top coat it, but can't find any good threads on method:
https://www.littlefairs.shop/products/littlefairs-extra-strong-varnish?variant=39424105971814¤cy=GBP&utm_medium=product_sync&utm_source=google&utm_content=sag_organic&utm_campaign=sag_organic&gclid=CjwKCAiAxJSPBhAoEiwAeO_fP3Ee7DuiHk1B9TpqbzK7voIO64JuMDwsFygmQMg_9g5fhN9dvS8ibBoCOfMQAvD_BwE
Available in matt or gloss.
I got a gloss "water based varnish" spray, which should be a clear acrylic, but I'm thinking I might go for a matt finish for a change.
Ahem...watching the build with interest
Instagram
Instagram
I will level that off tomorrow and see where we are at. I expect it will need two more coats before I start on top coat
Instagram
I'm not sure how matte it will be once done. With a bit of practice I could probably roll on a nice final coat and leave it that way.
More likely it will need some levelling, which burnishes it up to an eggshell like sheen. Adding oil will probably push it towards semi gloss, and obviously darken it too
Instagram
Anyway the coat of oil prevents adding more, so I'm currently experimenting with mixing milk paint powder with boiled linseed oil.
That seems to be getting more consistent after 1 coat
Instagram
My hope is to finish off with a few coats of osmo once I have a good consistent colour.
Instagram
