1Q22 Challenge Downbytheriver 335 style from a kit with stains
1235»
  • downbytheriverdownbytheriver Frets: 1055
    edited February 2022
    Unclamped and two strings fitted for checks - everything seems pretty much in line…
    All seems well, tension removed, start work on the electrics and string up in a day or two…
    (waiting for a reamer to arrive as the holes are drilled for mini pots)
  • Electrics in, strung…
    it works! Except the socket is a bit… not right, intermittent, you know… denial denial. Yup it’s going to have to come out!
    Left to do.
    The nut is higher than I would set it even for slide - much work required.
    Truss rod cover coming.
    Pickguard… options exist but it will definitely have one.
    Knobs - I have the gold ones that came with the kit - there might be a better option.
    Strap buttons to fit.
    A bit of a review of the kit…
  • Looks great! Don't spoil it with a pickguard ;)
    Nice one on getting the loom in place. I can't bring myself to even try...
  • it works! Except the socket is a bit… not right, intermittent, you know… denial denial. Yup it’s going to have to come out!
    Just leave it and say it's a Norman Collier signature guitar
    To be honest, using aquarium tubing, it was dead easy! I was most surprised.
    Have I mentioned the loom came from Mojo? Lovely piece of kit.
  • Nice one on getting the loom in place. I can't bring myself to even try...
    Very nice. I've ordered a pre soldered 3 way from alegree, but have the rest of the components I need for my wiring so I'll be ham-fistedly doing a bad solder job ;)
    That colour is really cool. It'll make a great guitar once you've finished.
    Intrigued by the tubing method ;)
  • Intrigued by the tubing method ;)
    Get some 6mm aquarium tubing, thread it through the holes, push it over the top of the pot and pull! I did all 4 pots at once with tubing, piece of wire for the socket and a finger to push the switch into place. I’m sure there are YouTube videos about this!
  • It's coming on nicely! :)
  • Well, obviously, the knobs that came with the kit don’t fit the CTS pots in the loom. SO… looking for knobs. I’d like chrome ones I think (seems to be the theme) - anybody have any ideas?
    Scratchplate - I think I’ll make a wooden one - this has the option to be a template for an engraved aluminium one later.
    Otherwise, once the nut is done, we’re pretty much there. It’ll need a case I guess.
  • Axesrus are my preferred supplier, often dispatching same day as order and arriving stupidly fast.
  • Finito pics, story in the finished projects thread.
  • I've said it before, but I really like that colour - we need more guitars that aren't the obvious sunburst, red or black.
    (Although I am guilty of owning a black bass...)
