although originals are similar in that regard
Instagram
Instagram
The top is a carved arch top, back is pressed into a 15' radius dome so not totally flat. I doubled up thickness by the control cavity so i could drill a grain matched and cross laminated cavity cover.
Top has 2 chunky parallel braces. Back has 3 smaller parrallel braces on the slant, and a couple of extra flat braces to hold the cavity cover in place.
Instagram
Cant wait to add the flamed maple binding to this
Instagram
I could also potentially get one under the f-hole for 2 vol/2 tone.
Instagram
The other consideration is how to route the wires so they are as hidden as possible. I don't mind one wire crossing the f-hole, wouldnt want to see a rats nest.
Instagram
I've stained the cover supports so only the main braces are visible through the f-hole. I've also added a label with a model name of "La Ville". It seemed a fitting choice as Paul Languedoc and I both have last names that come from places in France
Instagram
Still need to tidy up some details on it.
Instagram
Instagram
