Behold my massive board of pedals
1363364366368369394
  • robmac5150robmac5150 Frets: 182
    slacker said:
    https://i.imgur.com/8RWtGfI.jpeg
    The I don't think its going out of the house board btw all the silly price ones were bought years ago.
    Wise investments!!
  • slackerslacker Frets: 2254
    Wise investments!!
    Lot of it was luck. Part of it is that I keep them because I use them. I sold lovetone stuff at the going rate in the 2000s.
  • Axe_meisterAxe_meister Frets: 4659
    edited July 2022
    https://i.imgur.com/Bnp73xb.jpg
    JHS Cheese ball --> Bad Horsie --> Helix LT --> Loop 1 --> Hotone Switcher with Xotic SL, Home Made Zen Drive, Tone City Nobelman, 1986 TS9 --> Helix --> Loop 2 --> Marshall Origin 20 front end --> Helix --> Marshall Power section.
    Still a little bit of room for some more impedance sensitive pedals, thinking of a Fuzz Face as the Cheese ball is a little more Bug Muff sounding.
    Expression pedal on Helix has control over volume and FX mix levels for swell into Solo tones. The Boss Expression Pedal for Whammy FXs.
    The Hotone also switches the Boost on the amp.
  • LewyLewy Frets: 4256
     Not so much behold my massive board of pedals, more behold my board of massive pedal….
    …. along with board of slightly less massive pedal….
    1reaction image LOL 5reaction image Wow! 0reaction image Wisdom
  • solarsolar Frets: 174
    Not much change since last time. The Angel Teeth is new.
  • GavRichListGavRichList Frets: 7215
    ah, the Freeze. I miss mine - If I could fit one on again I definitely would
    I think this is maybe the fourth one I've owned? Plus multiple Superegos. Definitely not getting rid again! (honest)
    so great when used with other things. I used to have mine early in the chain and then run it through pitch and mods and such. Im eyeing my board up as I type to see if there's any crowbarring potential :D
  • KeefyKeefy Frets: 2323
    edited July 2022
    Latest iteration  of the Pedalboard of Glory - Spark and RDC out, EP clone and full size RD in, plus drive pedals re-ordered (again).
    ThorpyFX Peacekeeper
    Origin Efects Cali76 Compact
    Korg Pitchblack
    ThorpyFX Pulse Doppler
    EQD Colby Fuzz Sound
    Origin Effects RevivalDrive (with footswitch)
    DIY EP Boost
    EHX Deluxe Memory Man 1100TT (MXR 6-band EQ in loop, DIY tap/divide switch)
    Subdecay Vagabond
  • tone1tone1 Frets: 5187
    Few additions for me recently…Mojo Vibe-Les Lius-Boneyard-Boonar……Cornell Romany Plus 1 x12
    https://i.imgur.com/436jIzf.jpg
  • WazmeisterWazmeister Frets: 9615
    Nice board that Tone
  • dilbertdilbert Frets: 203
    roberty said:
    Retro board! Did this for a thing this weekend
    These are pedals I've used for a long time, the Rat, DD-3 and AD-9 are actual units I've owned for over 20 years. Kind of puts things into perspective. I sold my old DOD 250 because it didn't have an LED, shame cos it looked knackered like the rest of these
    For low-mid gain I use the 250 as a base tone and the Rat for a lead boost. For high gain I would reverse the order and have the Rat for the base tone and the 250 to boost solos. These pedals just work for me, can cover so much ground
    Reverb and tremolo on the amp
    @roberty, where did you get the patch leads with pancake connectors from?
    Cheers
  • JezWyndJezWynd Frets: 6118
    Not a board but a drawer, very convenient for playing at home. My bass pedals -
    1reaction image LOL 2reaction image Wow! 0reaction image Wisdom
    I’d like to see you get your foot in there!
    Now that is top-drawer!
  • elstoofelstoof Frets: 2521
    Just need to knock some patch cables up
  • Some amazing looking boards on here. My rudimentary home setup is coming along slowly :)
    I'm looking to get rid of the Chase Bliss and the Meris Enzo, just too effing complicated! Keen for any compressor advice if anyone has recomendations?
    https://imgur.com/yreWwwt
    https://imgur.com/d93Jta3
    edited August 2022
    That is one serious man cave!
  • SupportactSupportact Frets: 1001
    I like this. I want to think that you are playing the bass from inside a nearby wardrobe, so if someone comes in it just looks like the room is unoccupied.
    Having been previously embarrassed about having my pedals on top of my amp…..I’ve dug my Smorgboard out….I do have a Nordvang Incoming but this is currently my little lot….added the Peacekeeper (again)  <3
    https://i.imgur.com/HkryHTp.jpg
