What makes it Metal or Heavy Metal.?
bluecatbluecat Frets: 580
Is it all the rough shouting, or the endless widdly widdly guitar bits that are so unmelodic.
«13
  • SporkySporky Frets: 28636
    I don't think any of the metal I like has widdly widdly.
  • fretmeisterfretmeister Frets: 24544
    “A guitar oriented slightly distorted sound” was the original definition.
  • FunkfingersFunkfingers Frets: 14553
    Spandex and cucumbers, mainly.
  • Fishboy7Fishboy7 Frets: 2209
  • JeremiahJeremiah Frets: 631
    Lead guitar may or may not be heavy metal, but a guitar made of lead definitely would be.
  • Awwww, have the nasty heavy metal men hurt your little ear drums? Just put Santana back on. He’s doesn’t widdle at all.
  • mrkbmrkb Frets: 6907
    And ladies (and male singers) in fishnets?
    Karma......
    Ebay mark7777_1
  • I like plenty of metal that has neither widdly widdly guitars, nor rough shouting.
    I like plenty of blues that has tons of widdly widdly guitars and very rough shouting.
  • blobbblobb Frets: 2996
    I only joined the band because you said it was Heavy Metal.
    Feelin' Reelin' & Squeelin'
  • bobaccobobacco Frets: 535
    Howlin’ Wolf is basically Rob Halford, give or take half a dozen kilos of leather.
  • StevepageStevepage Frets: 3061
    It's clearly the leather underwear that makes it Metal
  • sev112sev112 Frets: 2788
    To quote Saxon … “Wheels of Steel”
  • OilCityPickupsOilCityPickups Frets: 10586
    To me Metal is just the most fun to play: I've played in bands from jazz and punk to rockabilly and blues = but I really have a ball when I can turn up and go a bit mad.
  • thermionicthermionic Frets: 9671
    I find the endless subgenres fascinating though:
    https://en.m.wikipedia.org/wiki/Heavy_metal_genres
    Some of them must have only a couple of  bands in them, each looking at the other’s integrity with disdain.
  • GoFishGoFish Frets: 1437
    Yes!! More Manowar! Moar!
    Though not more Yes, perversely enough.
    • To be a little serious - I always think that Heavy Metal actually predated Metal which had by then grown to cover other subgenres.
    • I'm pretty confused about the distinction between Rock and Metal. Things that were metal are now rock. But at the time, the distinction was very important. Also, some things are never Rock, only Metal. Manowar got this.
    • Rob Halford  is basically Howlin Wolf with a fluffer squeezing at the appropriate moment a high note is needed. Which is lots.
  • Philly_QPhilly_Q Frets: 23034
    I'm not sure how to interpret the question(s).  I thought the thread title was asking what's the difference between "Metal" and "Heavy Metal", but then the opening post seems to just be asking what metal/heavy metal actually is.
    Anyway, no simple answer.  And as noted, there's lots of metal with no rough shouting and/or no (allegedly unmelodic) widdly widdly bits.
  • LestratcasterLestratcaster Frets: 1093
    edited October 2023
    I'm more into metalcore which is a modern style of metal. More screaming but mixed with singing. More double kick drum copying the guitar riffs and syncopated rhythms. Also more use of production like synths and strings.
    To me 'metal' is the classic 80's bands or Metallica, Pantera etc. Metalcore is the 2009 era onwards like Parkway Drive, Killswitch Engage etc etc.
  • ICBMICBM Frets: 72539
    Black Sabbath
    Start there...
    It did.
    'Characterised by the bass following the guitar parts in unison' was one of the early definitions I think. 'Containing a prominent flat-5th interval' might be another one (a lot of it does).
    Anyway, Black Sabbath by Black Sabbath (on Black Sabbath :) ) does both.
    Sabbath are also probably the only one of the original 'heavy metal' bands who would now be considered Metal, rather than heavy rock or classic rock.
    I'm more into metalcore which is a modern style of metal. More screaming but mixed with screaming. More double kick drum copying the guitar riffs and syncopated rhythms. Also more use of production like synths and strings.
    I see Metal as like a huge banquet with a dish to suit every mood ... If you want and apocalyptic then Sleep or Candlemass, if you want Symphonic then  Dimmu Borgir ... there's Rammstein for theatrical moments or old school from Sabbath or Maiden ... currently I am really into these guys
     https://www.youtube.com/watch?v=GTzaT2cy2sU
  • I'm more into metalcore which is a modern style of metal. More screaming but mixed with screaming. More double kick drum copying the guitar riffs and syncopated rhythms. Also more use of production like synths and strings.
    It's a very broad genre let's put it that way. The old school stuff doesn't have as much detailed syncopation for rhythm, the newer stuff typically has breakdowns and 2-bar patterns for them with the 2nd repeat changing. The kick drum is definitely louder in the mix!
