At a previous job there was a CDM swoop when there was an accident on site (walkway collapse during construction, not one of my projects) ). They come in with the police and take you and a lot of files away, and ideally your employer scrambles a qualified solicitor straight away. It's every bit as serious as it should be.
The shipowners are very, very dodgy. There is no prima facie reason to imagine that the ship was safe and properly maintained. They have form.
Excerpted from here (worth reading as there is more): https://www.abc.net.au/news/2024-03-28/ship-owner-in-baltimore-bridge-tragedy-vessel-banned-australia/103642216
My brother-in-law used to be in the merchant navy and said the rules that once applied have been completely eroded under flags of convenience and it’s basically unregulated. And that was thirty years ago… I’m sure it’s worse now.
There seems a mass of truss bridges in the USA too.. you’d have thought a critical span like that would have been upgraded with a much wider and higher suspension bridge years ago. Maybe the Tacoma Narrows disaster put the public’s feelings back.
Q: Why did the Tasmanian authorities insist on spending the extra money to make it properly safe?
Ans: Because a ship ran into it in 1975 and knocked it down. People were killed. Hobart came to a standstill for many months because it was the only way to get across the water short of driving all the way upstream to Bridgewater and then all the way back again. The ship is still there under the water. It was too heavy and dangerous to move so they put the new bridge pylon in a different place.
(which is why no fucker will sign up to it and why PI and PL is through the roof).
Something like this bridge would be procured under something like NEC4 Option F - so in that instance the Employer would procure and nominate a single overarching PD.
There are even special "safety officers" on some projects, whose job is to ensure there is full and accurate evidence of safe design
Read up on SIL levels:
https://blog.msasafety.com/what-safety-integrity-level-means/
Last week I saw a photo of a bridge with protective barriers to stop ships damaging the piers - the Sunshine Skyway.
Searching for it today I found that the same thing had happened there, and the replacement bridge is the one with the protective barriers - you can see them in this photo. The old bridge is in the foreground.
I'm wondering if we'll see this type of barrier being retro-fitted around older bridges
Nil Satis Nisi Optimum
Genius!
Skip to the comments though and there are dozens of people who genuinely think it was a deliberate act, a part of some sort of government conspiracy - to what end I have no clue, nor do they. Some of the comments and reasoning is staggering - the ship lost power, it wouldn't steer off course so quickly after losing power at low speed, or , how come there weren't any tugs or pilot boats guiding the ship, to pick just two.
Beggars belief that people seem to want to believe everything that happens is something sinister and cannot possibly be just a case of sh!t happens!
Turns out there is an H in Haych! ~ Sporky
Bit of trading feedback here.
The problem is that the majority of individual designers and their employer and the clients of the projects do not know (a) what the actual law/CDM says and (b) don't k ow how to apply that law ans (c) their company procedures are all weak ! I know this from daily experience as well having examined numerous prospective Chartered Engineers for >20 years
Finally the HSExec does have an approach called "tolerability" and this is the real crux. What does society need which helps determine whether a risk is sufficiently addressed. They also consider that what is tolerable will change with time, as greater knowledge comes along and awareness of what they call "developing risks". - an example is fire from (the electrics serving) solar panels which exist on many roofs (there have been a lot of fires in Europe (different to EVs but that's another discussion )
Wasn't the stuff that exploded in Beirut the result of a ship that the owner was just able to walk away from because it was cheaper that way?
https://www.youtube.com/watch?v=1zD-KjuGuiM
My view is that the root issue is - as usual - growth capitalism. It corrupts everything.
