Guitar Weight and tone,,plus of course Compromise / usability..Not Tonewood..
1235»
  • KevSKevS Frets: 492
    Litterick said:
    I was looking forward to reading this discussion. Oh well.
    Arguments are that way,,this is being hit on the head lessons..
    Sporky said:
    I'm not sure why you keep pushing this idea that I'm not calm. I can assure you that it's incorrect and unnecessary.
    ARGGHHHHHH !!!!  I got the last word in...   So there..!!!
  • fretmeisterfretmeister Frets: 24623
    Sporky said:
    It's worship of lack of knowledge. I'm amazed at Fretmeister's patience - clearly KevS isn't going to read the book that will answer many of his questions.
    I think he'll read it - even if for no other reason than to try to prove you wrong!
    Go on KevS - get stuck in!
  • OffsetOffset Frets: 11991
    I must confess that since I seldom play a guitar on a strap, weight has never been much of an issue for me.
    Balance, however, is.
    Enter the Firebird :-(
    * EDIT - I posted this before perusing the previous three pages... oooof.  I'll stick to weight thanks :-)
    I used to be happy with a heavy instrument - explorers / les pauls / jazz basses etc.
    Then I got older! :D
    I've never found Les Pauls good as a sitting down instrument. Maybe at some point I'll have to try an SG.
  • SporkySporky Frets: 28674
    You could try my NSG then - heavy enough to cut off the circulation in your leg.
    I have became a Fan of the Guild S100,,the later Newark Street World Music made Korean ones I like..
    Better Balanced than the SG..I'm not a fan of the HB 1 pickups..
    The Korean ones have a 12 inch camber board and tun o matic,not a 20 and small frets and a really curved bridge like the American originals..The early Korean ones are heavy,,but my later 2 are under 7lbs..
    I also have a Black Guild Bluesbird from the same era and factory..Great guitar..
    Sorry..Did I mention this in my first post..
    No idea what the equivalent new Chinese Deluxe S100 series are like,,apart from being cheaper and I think the new pickups are PAF sized..Easier to change..
    That's the main sexy long bastard I play,,a bit longer than an SG..
    https://guildguitars.com/g/s-100-polara-black/
