Yamaha acoustics
1235»
  • SoupmanSoupman Frets: 238
    I tried a couple of Yamaha transacoustics a few months ago, the FG range have a 43mm (1 11/16") nut, the slightly more upmarket LL and LS models have 44mm (1 3/4") nut.
    The 43mm I found uncomfortably narrow, the 44mm I reckon I could learn to live with.
    In fact, 1 3/4" converts to 44.5mm . I don't know which measurement scale they actually use, but it felt like 44.5mm , based on my being used to playing 45mm.
    (We need a one of those smileys with a head being scratched here ...!)
  • BigPaulieBigPaulie Frets: 1114
    I measured my LL16's nut at 44.11mm.
    https://www.thefretboard.co.uk/discussion/244571/interesting-observation-on-nut-width-vs-string-spacing
    @BigPaulie that extra 0.11 mm makes all the difference...  =)
  • guitarjack66guitarjack66 Frets: 1890
    I'm glad you agree with exactly what I keep telling mrsguitarjack.
  • TanninTannin Frets: 5539
    You inspired me. 10 or 15 minutes worth of fossicking around in the shed looking for the micrometer I vaguely thought I remembered buying from Aldi's centre aisle one upon a time led (eventually!) to discovering it filed under "marking tools".  As with so many of those great gadgets you get from Aldi, I've had it for years and never once used it. It turned out to have a flat battery, but Aldi shipped it with a spare, which was thoughtful of them
    So I measured all my nuts, with the following results in the format:
    nominal size - actual measured size - model
    44mm = 44mm Cole Clark Angel III
    44mm < 44.3mm Paul Mineur custom build
    44.1mm  < 44.3mm Maton Messiah
    44.1mm < 44.45mm Maton custom SRS60C
    44.1mm < 44.5mm Maton Custom Shop WA May
    45mm > 44.65mm Furch Red
    46mm > 45.9mm Tacoma Thumderhawk baritone
    47mm = 47.0mm Paul Mineur custom baritone
    So of my 8 guitars, one is narrower than spec (but it's American made, so it presumably the actual spec was in imperial measure, so I'll write the difference off as a decimal conversion error).
    The Furch is BOTH narrower and wider than spec! They variously cite it as "45mm" and "1/3/4" - which is 44.5mm. At 44.65mm, it's closer to 44.5mm.
    Two guitars are exactly on-spec - laughably, they are the Cole Clark Angel III (where the neck will have been done very, very precisely by ultra-high-tech CNC), and the Paul Mineur baritone (made entirely by hand). Go figure.
    And the Matons vary significantly - from 0.2mm oversize for the Messiah to a remarkable 0.4mm oversize for the hand-made WA May.
