Drews Recording Thread
  • cheers, the drums one was really interesting, will prob check out the others after dinner
    ဈǝᴉʇsɐoʇǝsǝǝɥɔဪቌ
  • spark240spark240 Frets: 2086
    edited September 2015
    Dude...all great vids...personally as an S1 user I have loads of questions on that alone,..plus the usual general questions.
    Just on the vocals...any reason why you didn't use an FX send for all those verbs etc?
    Save on processing power?
    And...how come 2 x Pro EQ on some tracks?
    Mac Mini M1
    Presonus Studio One V5
     https://twitter.com/spark240
    Reddit r/newmusicreview
    spark240 said:
    Did you write the automation in real time with fader, or draw it in?
    Bit of both to be honest. Studio One does this automation clean up thing too, so when you ride a fader is kinda tidies up your crappy fader riding!
    spark240 said:
    Juts on the vocals...any reason why you didn't use an FX send for all those verbs etc?
    Mainly because I want multiple reverb tails all combined together, rather than a thicker single reverb if that makes sense?
    The first EQ usually serves to clean up resonance problems and to do a basic high-cut and low-cut. Then the second serves the more surgical stuff.
  • So watching the bass one now, the clank track, is that a duplicate of the other tracks or did you double track the bass? I pretty much always quad track distorted guitars but usually just use one take of bass.
    ဈǝᴉʇsɐoʇǝsǝǝɥɔဪቌ
    They're all totally separate recordings dude.
    Clean tracks - amp + cab + mics
    clank tracks - Darkglass + amp + cab + mics (all the low-end filtered)
    dirty tracks - Darkglass + amp + cab + mics
  • Drew_fx said:
    Dudes - I've decided to make this a video series and I'm going to start this weekend. Any preferences as to which song I should do???
    http://bridgedisaster.co.uk/album/wires-dream-wires
    @Drew_FX, I've got a preference.  Sex On Fire.
    You're a bell Chris.
    Takes sound tight!
    ဈǝᴉʇsɐoʇǝsǝǝɥɔဪቌ
  • Dunno why but I assumed you've be able to tell double tracks far more easily on bass.
    ဈǝᴉʇsɐoʇǝsǝǝɥɔဪቌ
    Sorry, I meant that they're different recordings. But they are all the same DI going through. Hence tightness!
  • How do you know frequencies to boost and cut on the drums?  Like how do you know the stick attack is the 3 - 5k region?
    Well you should always use your ears, and use the resonant EQ trick to dial it in. But there are some basic guidelines out there. I've just kinda learned from various online resources over the years. I recommend this book: http://www.systematicproductions.com/mixing-guide.htm
    And this one:
    http://www.mixingwithyourmind.com/
    They're the two best resources ever imho.
  • I haven't had time to actually watch the videos in full but basically what you are saying is that you recorded a load of stuff into the computer and the computer's do-dah sorted it all out into a song and made it sound good, right?
    Yes, I genuinely have been asked something very similar MORE THAN ONCE?
    But I'm your bell, Drew xxx
  • ClarkyClarky Frets: 3261
    reserved for future Japanese girl video
    Ahh interesting so you re-amped it basically?
    ဈǝᴉʇsɐoʇǝsǝǝɥɔဪቌ
    Yeah exactly. With different settings for each group essentially.
    And this one:
    Cool, thanks.
  • hugbothugbot Frets: 1528
    Yeah you just hit the button marked "pro tools" and it pro toolses it.
    If you want to get really fancy, use a little trick I like to call "audio exciter on every track then eq in a v shape". simple.
  • randomhandclapsrandomhandclaps Frets: 20521
    Mixing With Your Mind is one of the best books ever - quite probably the best book related to production I've ever read.  I recommend buying it direct though.
