The yard is nothing but a fence, the sun just hurts my eyes...
It’s actually hard to see how it’s happened, since they appear to be aligned at the bottom and the spacing looks quite even. There must be just enough variation for it to add up.
Are the white marks scratches or grout left on the surface?
Not OCD at all, a proper tradesman should be able to do better than that.
I doubt they would re-do it to be honest
Other things to consider
Who chose and purchased the materials?
Was the wall straight / the tray/bath/counter below?
Interestingly, my mate is a plumber who fits high-end bathrooms - customer chooses and purchases, he is assigned to fit them, and he has had 2 court cases in the last 3 years, where unhappy clients have tried to sue him for £10k-£30k for poor workmanship, whereas he and his tiler are top-notch
The one I remember is that the wall was not straight - it was concave, and they had told the customer in advance, so it looked odd. In both cases (after a huge amount of stress dragging on for about a year - that was causing him quite a lot of harm as far as I could see), he won both cases, plus costs. One of them was a customer who was actually a solicitor, must have been a very thick one - I saw the evidence, there was no case to answer. That customer lost, then took it to appeal, and had it rejected and more fees added, cost him about double in the end.
Our house was built in the late 1700's, the great thing about that is that there isn't a flat surface, or a horizontal or vertical line, or a 90 degree angle anywhere and you get used to this sort of thing. But even in our last house which was 1960's none of the tiling lined up perfectly.
The spacing looks even, so It's hard to see how it could be made better without carefully selecting the tiles to get each run the same height either side of the corner. Is that really practical?
