Finished Shots - Trini Lopez 335 ish Tribute
    The second back and sides are now thicknessed to around 1.9mm and so the next set of radius-shaped braces can be glued:
    Next job is cutting and bending the second side and end cap.
    And we have a pair of bookmatched backs :)
    0reaction image LOL 7reaction image Wow! 1reaction image Wisdom
    superb!
    I'm almost tempted to have two, with the second sporting a walnut front and an ebony back :-)
    meltedbuzzbox said:
    superb!
    Now you're talking the language I like ;)
    Second side cut and bent, here drying off in the mould:
    And the kerfed linings have arrived!  :)
    Here they are being glued using the old 'clothes pegs and rubber band' trick:
    Tomorrow, I should be able to do the same with the other side:
    And, we have two backs ready for trimming :)
    These two are around 1.5lbs together...not bad so far.  Now where's that lightweight ebony... ;)
    And it's time to cut the ebony - although it will be a while before this can be glued in place.
    I used the modded mould to chalk the outline:
    You can see how close the outline gets to the side, top and bottom on the widest piece of ebony I could find!
    And cut (always) oversize.  This is the cut pieces actually resting on the back assemblies:
    Total weight of the backs and tops together is 3 1/2 lbs.  Not bad, although you have to remember that there is a through neck to add to that!
    And so I'll be moving into a 'planning before doing' phase over the next couple of weeks - not least because there are some grandparenting duties looming which means 'moving all your mess out of the way'  ;)
    But there's a lot to get right and it is worth the pondering without the temptation of cutting or gluing something before I'm sure!
    This is where I'm at with the wings:
    The ebony is around 6mm thick and will have a subtle top carve, following the same sort of curve as the back, a couple of diamond 'f' holes and some weight relief scoops in the underneath.  And some very careful routing for the switches.
    Switches?
    Yes - we're going Jaguar switch system, back mounted.
    "And so I'll be moving into a 'planning before doing' phase over the next couple of weeks"  :)
    It's looking spectacular Andy!
  • Family commitments/holiday sorted and we're back to it :)
    The timber for the neck arrived a couple of weeks ago from David Dyke.  Remembering that the timbers will darken and the maple will yellow a touch once the finish is on, this is broadly how it will look front and back when it's glued and sized up:
    The first lamination is in the clamps gluing up as I type :)
  • Mahogany is now cut to a couple of mm wider than final width and 4 of the 5 pieces are glued:
  • And so that's pretty much all the structural components available except for the fretboard blank, which will be ordered this week:
    Just got to turn them into a decent, playable guitar now, then!
    *gulp*
  • The progress from now on will be a myriad of small, straightforward jobs and a few big and scary ones!
    This is in the first category - gluing the cutaway sides:
    Number 2 is gluing:
    While Number 1 is glued and the excess removed, ready - at some stage - for the bottom edge to be routed for the maple binding:
    edited September 2021
    The next stage is a bit chicken and egg.
    I have to cut the access hatches (yes - absolutely NO to feeding everything through the 'f' holes ) but therefore I need to agree with @meltedbuzzbox ; the best place for the Jaguar-type slider switches.  And, actually, that's not such a straightforward decision with so much stuff going on with the top.
    So, to help envisage it, I set about cutting the diamond 'f' holes.
    I drew their basic positions up:
    And marked up and cut them out slightly undersize - I will finish size them by hand before binding them with maple.
    And that meant I could do a more realistic mockup for @meltedbuzzbox ; in terms of where he would prefer the switches and knobs to go (still under consideration but we are probably looking at a triple row of slider switches (no plate) and two of three pots)
  • Wow would you look at that!
    I think I have an idea. I'll mull it over tonight and get back in touch sir
  • For straightening up the edges of the diamonds I used the humble cabinet scraper (a simple cheap scraper set is probably the best 'usefulness vs cost' tool you are likely to ever get!) and a small sanding block cut from a plywood offcut:
    A very sharp chisel and then a highly sophisticated clamping system to hold the bits in place while the glue was drying:
    One done, one still to go :)
  • Both done :)
    0reaction image LOL 9reaction image Wow! 2reaction image Wisdom
  • Can I have f holes? :)
    It's looking great Andy!
