Behold my massive board of pedals
1341342344346347394
  • FezFez Frets: 528
    Here is my old large board that I replaced with a metro 20 for my live rig. This one is just used at home now as a messing around board.
    PSU is an old Maplin one, patch leads just what I had kicking around.
    Don't touch that dial.
  • tuner>fuzz>boost>comp>drive>hotrod>echo>buffer(underneath)>deco>trem>spring>plate.
    Love this, I have the Revival Drive and thinking of getting a Cali 76 to go with it now!
    View my trading feedback here: http://thefretboard.co.uk/discussion/58681/
  • My first ever pedal board - I bought some of these pedals 20 years ago.
    Late 80's RAT, DD3 & BF-2 Flanger,  Everything else is fairly modern. Fulltone Clyde Wah has a build date of 6.6.6 !
    Has a bit of room for expansion, DS-2 will probably end up being a different Boss pedal/guest slot. The 3 loop switcher is by Buzz Electronics.
    I had this mad idea idea of building a board from 9mm ply instead of buying one to save money, and hiding all the the patch cables so I could use stuff I already had. In reality it just took forever to build, almost a year! Initially it was going to have angled blocks of wood for feet, but I realised that they would end up getting ripped off, so changed for some aluminium box section.
    Gave it a proper test run today into my SV20H, really happy with it, no noise from the power supply and silent switching between loops.
    Nice! What’s the Mk4.23 pedal? Looks like a boost.
    Cheers, yeah it’s a clean boost - useful when used moderately, say when switching
    between a humbucker and a single coil guitar, or if a bit of extra volume/drive is needed, but can get a bit lairy if it’s really turned up and you accidentally turn it on when going into a very loud already overdriven amp!
  • VJIvesVJIves Frets: 466
    That's a lovely selection, I think the happiest I've been with my reverb section was when I had the Talispanga pairing.
  • YorkieYorkie Frets: 1513
    Loving the sommer goodness!
    Jon
    Adopted northerner with Asperger syndrome. I sometimes struggle with empathy and sarcasm – please bear with me.
    My trading feedback: https://www.thefretboard.co.uk/discussion/210335/yorkie
    edited January 2022
    Important update to mine: stereo rig (the 'X-large' sniffer thingy, made with help from @ecc83), Roland stereo recorder, Morley volume/wah (mindblown), MXR Timmy (thanks @Classic) and MXR Carbon Copy (thanks @yorkio). Plus some more Sommer/Rean patch cables, also soldered at home
    So, 11 boxes in total. 7 I bought here. 1 I made with help from someone here. Couldn't be prouder.
  • LoobsLoobs Frets: 3832
    edited January 2022
     here's my modest, underwhelming little board
  • alalalkasaralalalkasar Frets: 364
    edited January 2022
    Looks good to me. The de7 deserves a lot of love.
    It does everything I need it to! Not nearly as complex or fancy as many others on here but I can get a lot of different sounds out of it.
    maharg101 said:
    Yorkie said:
    It might be because of my non-negligible Knopfler influence, but every time I see a Morley volume pedal I end up thinking I should make space for one.
    Jon
    Yeah, just picked up the Morley 20/20 volume. It's nice and compact, build quality is good, and the buffer doesn't colour the sound. The switchable minimum volume is a nice feature.
    Thanks for the inspiration. I managed to find a Morley wah/volume with boost and I am living the dream. It sounds good, it feels good and it has freed up the space I needed for my recorder. It’s a little yellow wonder.
    Jon
  • BabonesBabones Frets: 1206
    edited January 2022
    Behold my messy board! Thinking of getting a smaller Morley 20/20 Lead Wah, but not sure if it will sound much different.
    https://i.imgur.com/DbWT2mZ.jpg
  • thefezthefez Frets: 131
    A mess of wires but that'll change once I buy a board. El Pescadoro had some issues with hum before but seems to be silent in this configuration for some unknown reason.
    Still trying to figure out the Broadcast as I think I adjusted the gain pots down too low. Love the Blues Driver and Grand Magus though.
  • Fishboy7Fishboy7 Frets: 2205
    Thanks @brucegill for the latest addition of the Harmonious Monk.
  • brucegillbrucegill Frets: 722
    edited January 2022
     Nice one! And I always fancied a Burnside!
  • BintyTwanger77BintyTwanger77 Frets: 2233
    edited January 2022
    Great choice of trem. I will never stop raving about the Harmonious Monk. Really tempted to give the Golden Reverberator another go, though the Mercury 7 is still working magnificently for me.
  • MajorscaleMajorscale Frets: 1563
    Nice!  I do wonder if I’m the only person who runs the Harmonious Monk before all drives? Try it, you might like it too!
  • andy1839andy1839 Frets: 2197
    Now I'm no longer required in the band I can indulge in many drives at once.
    10 out of 10 for effort in making everything fit. You have all manners of sideways and upside down and even in-between rows :)
