Buying a 2nd hand les paul
  • BlueStratBlueStrat Frets: 966
    PLOP said:
    If you're not concerned about the name on the headstock you could look into other brands besides Gibson - The high end Epis are very good guitars and much less likely to be fakes simply because Slash/Jimmy Page/whatever never plays an Epiphone.
    There's also a ton of other brands who make LPs with varying degrees of similarity to Gibson, some make basically identical guitars, some add a few modern improvements like high fret access, headstock durability and G-string tuning fixes.
    But I understand if you're set on a Gibby, only a Gibby will suffice.
    It might be worth some links on here for people to check on the most obvious signs of a fake? I'm sure someone's made a big checklist at some point!
    Which other makes are recommended?
    I was looking at a PRS  SE 245 a while back, before a new bathroom interrupted my plans :D
  • Nah it’ll be fine. I bought 6 Les Pauls in 2021. All used. One from a shop, all fine. Make sure you look into them and I’m sure it won’t be an issue.
    you might need to change your username?
    I have one, and a Les Paul. The SE 245 is beautifully made, really top class. Body is mahogany. It does have a real maple cap too - though it is then topped with a very nice real-wood veneer. The pickups are the best I've had on an SE - quite pokey, great for rock/metal - not exactly PAF. Neck and fret work is superb. Thanks to the belly carve and slight chamfer on the top it's more comfortable to play than my Les Paul.
  • mikeyrob73mikeyrob73 Frets: 4675
    Tokai
    i love mine , better than any of the gibsons i have owned and cost me less
  • bertiebertie Frets: 13572
    edited January 2022
    I was looking at a PRS  SE 245 a while back, before a new bathroom interrupted my plans D
    a nice Japanese  Love Rock  perhaps.............. if you knew someone on the forum selling one.....................
    https://www.thefretboard.co.uk/discussion/216917/
  • rlwrlw Frets: 4736
    edited January 2022
    Have to say that you can't go wrong with a proper Tokai.  Better built and better specs than Gibson pound for pound.  And a doddle to buy from Japan.
    The cost of this one, landed and all taxes paid and delivered to your door, is under £1100.00.  The Gibson equivalent adds £1000 to that for some reason.
  • TimmyOTimmyO Frets: 7580
    edited January 2022
    I'd be as worried about buying a not-that-great-real-one as a fake one. I've played some epic Les Pauls and some thoroughly 'ok' ones - I don't think it's a model I'd buy at a distance
    Red ones are better.
    Send it back if you don't like it, if buying new.
  • timmypixtimmypix Frets: 2433
    Some reason being a bit for a full flamed cap as opposed to a veneer, a hard case.... and then the majority for the brand name.
    Tim
    MIJ Tokais arent veneer,  well not unless you call 1/2" veneer :s
    No, you're right.  I thought one thing and did another.  So, full maple cap, one piece long tenon neck, CTS pots etc, case.
    Yours for £1350.00 and still a lot cheaper than a Gibson Standard.
    Well the listing seems to suggest a veneer? Seems odd to specify flame pieces and plain pieces:
    BODY : Flame Maple 2Pieces & Plan Maple 2 Pieces Top/ Mahogany 2 Pieces Back
    Just had a quick Google and the Tokai NL site says it's a veneer too. Looks like you need to get into the "Premium" range as opposed to the "Vintage" range to get a flamed top in the LS150.
    Tim
    edited January 2022
    maybe to get a flame  -   here's my LS-65 plain top
    Just to add that there's a lot of MIJ models that don't make it onto the Tokai NL site, so all sorts of odd numbers.
    rlw said:
    That’s got to be the best looking LP I’ve laid eyes on
    Whats so wrong about a flame veneer over a maple cap? I don’t think it would bother me if it looked like either of @rlw ’s examples, awesome looking guitars to my eye
    Nothing at all! But someone pointed out an equivalent Gibson would be £1000 more, so I was just suggesting that veneer vs full flamed cap might be a factor (although the brand is probably the bulk of that).
    Tim
    'Twas me but since corrected.
    Are tokai similar quality to FGN? I’ve had a few FGN made Ibanez Prestige RGs and the quality is top notch. Looking at Coda earlier and noticed they have an FGN LP
