No new models though; just bugs.
Heres the blurb:
“Tilt is a subtle 6dB EQ that boosts high frequencies while simultaneously attenuating low frequencies (or vice versa). Great for quickly making tones a bit brighter or darker. The Center Freq parameter sets the frequency around which the boost and cut pivot. “
Tilt EQ has been around since the 1970's. I think that Quad were the first to market it.
With the first two options, I often set the switch to momentary rather than latching, so it only applies when I have the switch pressed down.
How the fuck do the parallel paths and sub paths work?
Most things in Helix are really intuitive but I can't figure this out for the life of me.
There doesn't seem to be a simple way to have two paths that you can switch between (eg one chain for clean and one for dirty). Am i missing something? I can see how you'd do it by assigning a button to switch between the A/B block panned 100% to either side but that seems ridiculously convoluted.
Can anyone help? Bonus points if anyone can explain the difference between the A and B paths and the subpaths. I've still to establish when I'd ever use a B path (or even how to use the B path).
Thanks
Is this really the best way to do it? It seems really inelegant by helix standards.
If you create an A/B Split, then you can assign "route to" to a switch and toggle between A100 (min) and B100 (max).
Even though I've worked this out, I do find the way the splits work to be really unintuitive tbh. Turning a split "off" doesn't do remotely what I'd expect it to.
less blocks available though cos you wont have those two extra signal lanes..
