Had intended to try this weekend, but its due to piss down the next 5 days
Spatchcock it. Do it hot - 375-400F (205C) so you get a nice crispy skin.
Bit of hickory as the smoke wood - but not too much as it will go bitter.
If you have an injector rig then injecting a 50/50 salted butter and olive oil mix into the breast meat is lovely. Add some garlic powder into the mix as well if your needle is wide enough.
If you haven't got a syringe for that, then put little slits in the breast skin and push some butter & garlic under the skin.
at 400F / 205C it won't be that long to cook - check it after an hour. Probably only need 90 mins. Take the temp from all over the bird to make sure it's done. The thighs are usually the last to get up to a safe temp so definitely check there.
Hot and fast is the best way for chicken. Long slow cooks just dry it out. Chicken takes on smoke wood flavours far easier than other meats so you get plenty of flavour in a shorted cook.
The reason why rotisserie chicken is so good is because of really high temps for a short cooking time with the rotation to stop burning - I got a rotisserie unit for my kettle in the end, but I still do spatchcock for larger birds.
we need to get this thread back up and running for this year.
Did a smoked chicken on the Weber yesterday for Easter lunch, tasted great. Leftovers tonight are going into fajitas or tacos (or something like that)
I was in Costco today and spotted their briquettes, 15kg for £18, which seems a decent price if they are any good. Anyone tried them ?
https://www.costco.co.uk/Garden-Sheds-Patio/Barbecues-and-Firepits/Barbecue-Fuel/Bar-Be-Quick-Charcoal-Briquettes-15kg/p/338574
