Feedback
I haven't worked out why they don't fall over when the ship accelerates along its long axis though. Hmmmm....
Or is that the wrong franchise?
The other big chronological problem is the other way round - Moses Ingram is 28, so too old to be a grown-up youngling only 10 years later.
But never mind. If you try to overanalyse it you just fall down plot holes the size of a planet, as already said .
Yes I could go through it in more detail and pick out the inconsistencies but right now I don't care about any of those. It got close to hitting that same emotive spot the original did when I was a nipper and that'll do for me.
Some other stuff in SW might make sense if they have no artificial gravity in the fighters, like the little half roll to avoid negative G when they attack the Death Star.
In shows where ships do turn on their axis, like babylon 5 or nu bsg, it allows them to strafe more safely, but they maintain a constant speed and direction while doing it, which is... risky.
When they combine it with applying power though, they would be a devil to hit.
