Still trying to decide if I need a proper fuzz/distortion, or whether ramming the Phat Mod with a level-cranked TS is enough. Quite tempted by the Ibanez 850 Fuzz Mini, which would knock the Ditto onto the carpet.
Need to drill the board to fit my 1Spot CS6, then work out what I can safely use with split inputs. Drives and compressors should all be fine together, but what about the phaser? No BBD chips, but it has an LFO so it might be noisy.
Only home use so the practicalities of switching between them isn't a concern!
maybe a switch topper on one or the other?
So yes, if it's sparkling - dare I say, Fender-like - cleans you're after, the SBUS is much more in that line. By design, of course!
Its on a Metro 16 so I think it counts as small, its a bit Tetris at the moment, not sure if the EQ and the reverb are staying (the reverb is quite noisy but otherwise really good)
https://i.imgur.com/Qb9nQhy.jpeg
