Instagram
Instagram
Instagram
@WezV amazing craftmanship and I followed all of this fairly easily. The only bit I don't get is how you did the neck joint. I assume you made the tenon on the neck parallel to the fretboard and mounted the body on a table and then made an angled overhead router jig for the body rout recess to accommodate the neck, then measured the depth of the neck tenon and set the router accordingly minus the fretboard depth?
And the other thing was the body binding rout. Did you do that with the body on it's flat side on the router table with a bearing bit?
Still, a hell of a lot of craftsmanship though eh.
Instagram
Instagram
Instagram
Instagram
Instagram
Instagram
Instagram
Instagram
