Let's see your small/mini/nano pedalboards
  • Th4fonzTh4fonz Frets: 266
    Alexlotl said:
    Th4fonz said:
    What interconnects are you using here? I’m trying to go from a Metro 16 to a Nano+ at the moment, and all my plans that look lovely on Pedal Playground get scuppered due to cable width. This looks much tighter than I’ve managed to achieve.
    @Alexlotl Im using the EBS pg10 gold patch cables here with a Cioks dc7 underneath.
  • TimmyOTimmyO Frets: 7688
    @Greatape it's great. Coloured and most amp like of anything I've heard, kinda like an Origin revival drive in that sense. Very smooth high end. I love putting a treble booster in front.
    I have a Blackstone too - it's really VERY good isn't it.
    Red ones are better.
  • soma1975soma1975 Frets: 6976
    Can it play nicely with a fuzz face? The website schtick makes it sound like it would be an impedance nightmare.
  • Winny_PoohWinny_Pooh Frets: 7853
    Before or after? I 've run a fuzzface (needs to be bright-ish though) in front, into the low gain channel) and you can get a super compressed killer ZZtop type tone like that.
    Cool yeah my fuzz is always first. Might have to try one soon. Cheers.
  • Rod.DRod.D Frets: 4
    edited August 2023
    I have been experimenting with battery powered small boards using the pedaltrain nano
    https://imgur.com/a/vuVqDbi
  • stickyfiddlestickyfiddle Frets: 27542
    +1 for the Blackstone love. Highly underrated. Haven't tried it with a fuzz face but I think Blackstone over-egg the impedance thing on the blurb. I've run it after other pedals and it's just fine imo
  • solar said:
    solar said:
    Finally put a small board together for an upcoming jam/possible band/project.
    The Echo Master is still a "maybe".. we haven't decided whether we're going to be instrumental or not yet :lol:
    Maaaan, I wanna hear that!
    Is the Death by Audio the distorted delay that Jack White used live on last year's tour? If so, that's a crazy sounding thing!
    You mean the big blue one at the top? No, it’s an Echo Master, a vocal delay with XLR in and out.
    Yes that's what he uses on his mic stand, his is black though that's why i was checking
    soundcloud.com/thecolourbox-1
  • BrioBrio Frets: 1913
    edited August 2023
    Everything I need for my limited gigging.
  • DanDan Frets: 447
    Hopefully a Pedaltrain Metro 16 counts as small?
    Oooh, two Timmys. They look roughly same settings from this angle, how are you using them, are you stacking them?
  • DanDan Frets: 447
    Yeah pretty similar. Stacking them and set as a bit of hair and then kick the other for a bit more. I guess just trying to emulate the Tim which is on my bigger board.
    a lot of power in a small space there!
  • Board is growing in size again. I've ditched the Boss BCB-30 plastic case in favour for a PT Metro. Am I still allowed in this thread?
    Guitar>tuner>HSE TS/ZVEX>D&M Drive>Katana Boost>Ventura Vibe>Bucket Brigade Delay> HOF Reverb.
    Everything goes through the Gigrig Quartermaster except for the tuner.
    I use the Ventura Vibe on the rotary setting which I prefer after my drives.
    Just waiting for a larger PSU to arrive before I can get it up and running fully.
  • cm01cm01 Frets: 477
    edited September 2023
    Just had a little re-jig after picking up another M9, which sounds great.  Pushing the definition of nano a little!
  • oeljadioeljadi Frets: 25
    edited October 2023
    I've just downsized from a Mono Pedalboard Medium to a D'Addario X-PND. Had to cut out the volume, chorus and trem. But this may be all I realistically need. In > Empress Buffer > Shanks > Nordvang > Timeline > Empress Buffer > Out. Tuner is connected to the Empress via a dedicated tuner out. Cabling needs a tidy! Powered by an Ojai R30.
  • Current gigging rig for my 50s rock n' roll band...
    Guitar > Nocturne Atomic Brain Preamp > TC Electronic Echo Brain > TM Princeton
    0reaction image LOL 5reaction image Wow! 3reaction image Wisdom
  • KebabkidKebabkid Frets: 3341
    edited October 2023
    Just started putting this one together from spare pedals that came off my big board following a HX Stomp coming in.
    For those not familiar with the Sinvertek N5, it's a great and versatile preamp overdrive and you can select 2 different types of boost (a gainier push one or a volume jump one or both) which can be activated by a double-depression of the switch.
    I had this up for sale but it's just too good and too useful to let go.
    Tuner and all my fx come from the Zoom and that's a PT Nano. It's all powered by a GigRig Generator on the underside
    edited October 2023
    My new ampless rig on a Pedaltrain Metro 24.
     https://youtube.com/shorts/19bDCiGiJVo?si=fl5G6io3QpGFbqN6
    All power is from the Amped 3.
  • spev11spev11 Frets: 393
    The beam splitter has arrived and I honestly need to remove a drive and maybe the fuzz, they are both great but the MT2 can do low gain quite well really and the beam splitter does everything else. I rarely use the fuzz (or the chorus really) so I may boot em off and get my ambient reverb back on and chuck it at the front in gate setting to see what happens
