Been uploading old tracks I recorded ages ago and hopefully some new noodles here.
https://imgur.com/a/vuVqDbi
soundcloud.com/thecolourbox-1
Yeah pretty similar. Stacking them and set as a bit of hair and then kick the other for a bit more. I guess just trying to emulate the Tim which is on my bigger board.
Guitar>tuner>HSE TS/ZVEX>D&M Drive>Katana Boost>Ventura Vibe>Bucket Brigade Delay> HOF Reverb.
Everything goes through the Gigrig Quartermaster except for the tuner.
I use the Ventura Vibe on the rotary setting which I prefer after my drives.
Just waiting for a larger PSU to arrive before I can get it up and running fully.
Guitar > Nocturne Atomic Brain Preamp > TC Electronic Echo Brain > TM Princeton
For those not familiar with the Sinvertek N5, it's a great and versatile preamp overdrive and you can select 2 different types of boost (a gainier push one or a volume jump one or both) which can be activated by a double-depression of the switch.
I had this up for sale but it's just too good and too useful to let go.
Tuner and all my fx come from the Zoom and that's a PT Nano. It's all powered by a GigRig Generator on the underside
https://youtube.com/shorts/19bDCiGiJVo?si=fl5G6io3QpGFbqN6
The beam splitter has arrived and I honestly need to remove a drive and maybe the fuzz, they are both great but the MT2 can do low gain quite well really and the beam splitter does everything else. I rarely use the fuzz (or the chorus really) so I may boot em off and get my ambient reverb back on and chuck it at the front in gate setting to see what happens
