Many thanks
I bought a 5 litre tin a few years ago for about 35 quid and still have over half left. Use it for tables and doors etc around the house. Really brings the wood to life. Mine is the stripped pine "colour" so has a slight tint in it. Used it on my Tele that I stripped a few years ago and really brought out the grain:
No doubt the snake oil will do the same just a bit more pricey..
My cat has just confirmed his long term suspicion that I am an idiot who takes pictures of things and posts them on guitar forums. I've just applied a third coat and so this is covered in the 'wax', I'll do this for a few more days and report back my findings sometime next week.
I have buffed off the wax between coats and then reapplied each time, rubbing the wax into the grain each time. In theory, it should get darker after multiple applications.
https://i.imgur.com/JyJYgIQ.jpg
https://i.imgur.com/ujKC1D5.jpg
Ebay mark7777_1
I use a mix black and dark brown mix leather dye after fine sanding the board.
2 applications.
leave to dry overnight each time
Then I use tiny tin amounts of Tru-Oil to seal. Rub hard until it's not there.
leave 24 hours
Then bore oil.
result is always fab - he'res one I did a couple of weeks ago.
My band, Red For Dissent
This looks the way .
looking at the replys above , 4 coats of the snake oil and it's slighly darker .
Where as 1 coat of black leather dye and boom ! .
I've got the black leather dye to do my Tokai lp custom fretboard but it was how to seal it that has been holding me back , bit worried about black finger ends after playing a few minutes .
Instagram
Edit: do you have a ‘before’ photo so we can see the difference that the process has made?
