Montys "ageing wax" snake oil? or good ?
  • Slash'N'burnSlash'N'burn Frets: 162
    edited December 2020
    Ronseal Shed n fence preserver in chestnut brown?
    I'll try creosoting my guitar, see if that makes a difference.
  • I've got Fiddes wax with a tint in it. I bet it does the same thing at a fraction of the cost
    Could you point us in the direction of the exact one you use please?
    Many thanks
  • I pulled the trigger on a small tub of the wax. I never used lighter fluid to clean a fretboard before. Anything I should be aware of?
  • stonevibestonevibe Frets: 7165
    Don't light a cigar near it when you are rubbing it in...
    3reaction image LOL 0reaction image Wow! 2reaction image Wisdom
    Many thanks
    @Fortheloveofguitar ;
     I bought a 5 litre tin a few years ago for about 35 quid and still have over half left. Use it for tables and doors etc around the house. Really brings the wood to life. Mine is the stripped pine "colour" so has a slight tint in it. Used it on my Tele that I stripped a few years ago and really brought out the grain:
    No doubt the snake oil will do the same just a bit more pricey..
    Day Three
    My cat has just confirmed his long term suspicion that I am an idiot who takes pictures of things and posts them on guitar forums. I've just applied a third coat and so this is covered in the 'wax', I'll do this for a few more days and report back my findings sometime next week.
    I have buffed off the wax between coats and then reapplied each time, rubbing the wax into the grain each time. In theory, it should get darker after multiple applications.
    https://i.imgur.com/JyJYgIQ.jpg
  • mrkbmrkb Frets: 6921
    stonevibe said:
    Difficult to tell of it’s made any change- can you post before and after photos next to each other in the same post? Do you think it’s made any difference?
    Karma......
    Ebay mark7777_1
  • rze99rze99 Frets: 2359
    I use a mix black and dark brown mix leather dye after fine sanding the board.
    2 applications.
    leave to dry overnight each time
    Then I use tiny tin amounts of Tru-Oil to seal. Rub hard until it's not there.
    leave 24 hours
    Then bore oil.
    result is always fab - he'res one I did a couple of weeks ago.
    IMG_7427JPG
    IMG_7399JPG
    IMG_7403JPG
    1reaction image LOL 3reaction image Wow! 0reaction image Wisdom
    mrkb said:
    I would say that it is a shade darker at most, but it isn't drastic and so you'd be better off using traditional dyes/stains if you want a much darker look.
  • The wax looks really interesting but I'd be concerned if it left me with a Floyd Rose on a Strat  :o
    Trading feedback info here
    My band, Red For Dissent
    3reaction image LOL 0reaction image Wow! 4reaction image Wisdom
  • OffsetOffset Frets: 11993
    I use Brandon Bespoke Chopping Board & Butcher's Block Mineral Oil for treating my rosewood 'boards.  250ml cost me £11 - it's the best there is, I'm reliably informed.  Won't necessarily age but it'll certainly protect and preserve.
  • mark123mark123 Frets: 1326
    2 applications.
    leave 24 hours
    Then bore oil.
    IMG_7427JPG
    IMG_7399JPG
    IMG_7403JPG
    This looks the way .
    looking at the replys above , 4 coats of the snake oil and it's slighly darker .
    Where as 1 coat of black leather dye and boom ! .
    I've got the black leather dye to do my Tokai lp custom fretboard but it was how to seal it that has been holding me back , bit worried about black finger ends after playing a few minutes .
  • @rze99 looks great, what’s the brand for the dye? Cheers
  • dilbertdilbert Frets: 203
    +1. Inquiring minds need to know!
  • WezVWezV Frets: 16791
    Feibings leather oil/dye is the usual one..... as used by many guitar factories.
  • fretfinderfretfinder Frets: 5073
    2 applications.
    leave 24 hours
    Then bore oil.
    IMG_7427JPG
    IMG_7399JPG
    IMG_7403JPG
    Looks like a great result - no idea why someone lol’d your post though, very strange.
    What kind of tru-oil and bore oil should you use though? I’ve just had a browse on eBay and there’s a few types available and there doesn’t seem to be much to choose between them apart from the price. Also, I guess if you don’t want quite such a dark, almost black colour you could use just a dark brown leather dye? Cheers.
    Edit: do you have a ‘before’ photo so we can see the difference that the process has made?
    mark123 said:
    2 applications.
    leave 24 hours
    Then bore oil.
    IMG_7427JPG
    IMG_7399JPG
    IMG_7403JPG
    My method limits the rubbing off on fingers. The Tru-Oil seals in the dye pretty well. The trick is to be patient and let everything dry out fully.
    It's regular Dylon.
