I only use in the front, never had an effects loop.
Now got a Rockboard Quad 4.1 with Mod I/O module.
Chain is - RMC 10 wah - Catalinbread Octapussy (new addition that sounds ace) - Sonus 68 Jimi Mod Fuzz - Castledine Supra Vibe - Camelfish Treble Booster - GFI Orca Delay - Flamma Reverb
Been uploading old tracks I recorded ages ago and hopefully some new noodles here.
Most of this has been long term, but I've finally settled on a chorus (at last!!), and added the Veteran, Rubber Soul, Duellist and M1A recently. I'm not 100% on the Veteran but so far it's staying.
Guitar - Veteran - Fat General - Rubber Soul into DPC5.
Loop 1: Mayo
Loop 2: KHDK Mini Screamer
Loop 3: M1A
Loop 4: Duellist (replaced the KOT)
Loop 5: PastFX Chorus
This goes into the amp, then the Timeline and Expanse are in the FX Loop of my PT15.
I use so many FX as I have 2 amps I use separately, so for the PT15 I use the Treble Boost part of the Veteran, KHDK, Chorus, Timeline and Expanse.
My other amp, Dr Z Jaz 20/40 has no loop but an awesome spring verb, so all the other pedals I use for that. The Mayo and M1A are literally OMG into that amp.
The yard is nothing but a fence, the sun just hurts my eyes...
I often swap the Flight Time for a Volante.
Not sure I need the Small Stone on there as well but I have a spare slot I suspect that'll become a guest pedal spot just for anything I want to combine with the HX One but I'm not aware of anything specific at the moment. Sadly the HX can't quite do a proper Talkbox otherwise I'd drop that as well. That said I need that & pitch shift at the same time so the HX is busy!
I don’t usually run the front of the Magnatone super hot, but I’m still mulling over some kind of effects loop splitting. Problem is it would have to be stereo, and frankly it would border on a bit OTT. I’d rather just buy a cheap reverb pedal and maybe move the CC to live in the back of the amp and run through the effects loop permanently off the board.
I can either use the boost from the Thorpy veteran or the "Mick's" side of the D&M for more db's.
Gone back to the Klon as the 'always on' pedal for the upcoming project.
Added a QMX.
I hate this volume pedal but it is the only one that fits the board.
The Sidecar is outrageously awesome.
Cabling error.
Wondered why it sounded weird.
